I've selected 1.8V Lcdc as someone once said that helped stop flickering.
Kitkat Kernels for All (well most!)
Originally posted by m4f1050 View Post
I've selected 1.8V Lcdc as someone once said that helped stop flickering.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by m4f1050 View PostTesting. Is this for NCR MTK 1 or should I try NCR 3.1?
Whichever you want I guess. Originally you said WiFi only works on MTK1.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Giving it about 5 more mins, will post DMESG + GPIO dump (if you still need GPIO dump)
debug11.txt
NOTE: On my test TV (Sceptre 40") at 1080p I get the flickers and lines (just about anywhere, not just playing movies but I did not get any sound problems and the flickers/lines are barely noticeable while playing a movie - you really have to watch closely and on dark scenes) but not on my other TV's last night I watched 2 full movies with 0 issues.
Originally posted by Benobi View Post
d33, did you notice this?
Code:<4>[ 2.362168] mt6622_probe. <4>[ 2.362196] mt6622 power_gpio is busy! <6>[ 2.362234] [MT6622] mt_bt_power_init
Originally posted by nagper View PostThanks for the deatiled explanation!!
If I am getting you right you are keen to make a dedicated kernel for just me and the others would like native 1366x768? That would be perfect
Is it correct that issuing "wm size 1366x768" from a terminal inside android sets the desktop resolution? If it is, we just need your dedicated kernel to put our Tv-s to 1366x768.
Thank in advance.
Thank you
Here is a DMESG + GPIO on stock 720p MTK 1 (I turned BT on and off a few times, renamed the device and turned it off)
stock_mtk1_bt_test.txt
This DMESG + GPIO is after turning it back on
gpio.txt
I did notice on stock 720p there is no gpio busy message on BT...
Code:<6>[ 0.514916] Bluetooth: Core ver 2.16 <6>[ 0.514993] NET: Registered protocol family 31 <6>[ 0.515033] Bluetooth: HCI device and connection manager initialized <6>[ 0.515090] Bluetooth: HCI socket layer initialized <6>[ 0.515139] Bluetooth: L2CAP socket layer initialized <6>[ 0.515201] Bluetooth: SCO socket layer initialized <4>[ 0.516322] rk fb probe ok! <4>[ 0.521154] act8846_set_init,line=17 <4>[ 0.521190] act8846_set_init:g_pmic_type=3 <4>[ 0.522898] act8846_set_init act_dcdc1 =1200000mV end <4>[ 0.524698] act8846_set_init vdd_core =1000000mV end <4>[ 0.526491] act8846_set_init vdd_cpu =1000000mV end <4>[ 0.528288] act8846_set_init act_dcdc4 =3300000mV end <4>[ 0.529482] act8846_set_init act_ldo1 =1000000mV end <4>[ 0.531173] act8846_set_init act_ldo2 =1200000mV end <4>[ 0.532862] act8846_set_init act_ldo3 =1800000mV end <4>[ 0.534554] act8846_set_init act_ldo4 =3300000mV end <4>[ 0.536245] act8846_set_init act_ldo5 =3300000mV end <4>[ 0.537938] act8846_set_init act_ldo6 =3300000mV end <4>[ 0.539030] act8846_set_init act_ldo7 =1800000mV end <4>[ 0.540719] act8846_set_init act_ldo8 =2800000mV end <4>[ 0.540770] act8846_set_init,line=78 END <4>[ 0.540805] The PMU device is act8846 <4>[ 0.540875] i2c-core: driver [act8846] using legacy suspend method <4>[ 0.540927] i2c-core: driver [act8846] using legacy resume method <6>[ 0.541004] Switching to clocksource rk_timer <6>[ 0.547323] Switched to NOHz mode on CPU #0 <6>[ 0.547971] Switched to NOHz mode on CPU #3 <6>[ 0.548003] Switched to NOHz mode on CPU #2 <6>[ 0.548018] Switched to NOHz mode on CPU #1 <4>[ 0.550337] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xdf0ac000 <4>[ 0.550437] fb0:win0 <4>[ 0.550443] fb1:win1 <4>[ 0.550448] fb2:win2 <4>[ 0.550549] rk3188 lcdc1 clk enable... <4>[ 0.575672] rk3188 lcdc1 clk disable... <4>[ 0.611490] fb0:phy:97d00000>>vir:e0000000>>len:0xb00000 <4>[ 0.611799] rk_fb_register>>>>>fb0 <4>[ 0.612163] rk_fb_register>>>>>fb1 <4>[ 0.626876] rk3188 lcdc1 probe ok! <6>[ 0.688110] IT66121 probe success. <3>[ 0.689342] emmc emmc: internal_storage is NOT emmc <6>[ 0.689546] NET: Registered protocol family 2 <6>[ 0.689697] IP route cache hash table entries: 16384 (order: 4, 65536 bytes) <6>[ 0.690069] TCP established hash table entries: 65536 (order: 7, 524288 bytes) <6>[ 0.691126] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) <6>[ 0.692259] TCP: Hash tables configured (established 65536 bind 65536) <6>[ 0.692314] TCP reno registered <6>[ 0.692350] UDP hash table entries: 256 (order: 1, 8192 bytes) <6>[ 0.692413] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) <6>[ 0.692755] NET: Registered protocol family 1 <6>[ 0.692975] Unpacking initramfs... <6>[ 0.763293] Freeing initrd memory: 1344K <6>[ 0.763422] PMU: registered new PMU device of type 0 <4>[ 0.763557] efuse_version_val: efuse version = 51 <4>[ 0.763602] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 5000 <4>[ 0.763663] efuse_version_val: efuse version = 51 <4>[ 0.763704] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 5000 <4>[ 0.764917] rk3188 cpufreq version 2.2, suspend freq 816 MHz <4>[ 0.765250] vpu: power on <6>[ 0.765323] VPU_SERVICE: checking hw id 4831 <4>[ 0.765860] vpu: power off...done <6>[ 0.765919] VPU_SERVICE: init success <6>[ 0.766288] audit: initializing netlink socket (disabled) <5>[ 0.766367] type=2000 audit(0.700:1): initialized <4>[ 0.767057] highmem bounce pool size: 64 pages <6>[ 0.767238] ashmem: initialized <6>[ 0.773555] fuse init (API version 7.16) <7>[ 0.773889] SELinux: Registering netfilter hooks <6>[ 0.775413] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) <6>[ 0.775480] io scheduler noop registered <6>[ 0.775516] io scheduler deadline registered <6>[ 0.775605] io scheduler cfq registered (default) <6>[ 0.783537] rga: Driver loaded succesfully <4>[ 0.783812] rk_serial.c v1.6 2013-12-23 <6>[ 0.784145] rk_serial rk_serial.0: dma_rx_buffer 0xffdfc000 <6>[ 0.784194] rk_serial rk_serial.0: dma_rx_phy 0x7d0b4000 <6>[ 0.784248] rk_serial rk_serial.0: serial_rk_init_dma_rx sucess <6>[ 0.784304] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0 <6>[ 0.784506] rk_serial rk_serial.0: membase 0xdf0c4000 <6>[ 0.784637] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3 <6>[ 0.784817] rk_serial rk_serial.3: membase 0xdf0c8000 <6>[ 0.785169] Rockchip ion module(version: 1.0) is successfully loaded <6>[ 0.788186] loop: module loaded <6>[ 0.788255] Android kernel panic handler initialized (bind=kpanic) <4>[ 0.788340] mt6622_probe. <6>[ 0.788368] [BT-PLAT] mt_bt_power_init <4>[ 0.919753] ******** Show Sink Info ******** <4>[ 0.919785] Support video mode: <4>[ 0.919808] 1920x1080p@60Hz. <4>[ 0.919829] 1920x1080p@50Hz. <4>[ 0.919849] 1280x720p@60Hz. <4>[ 0.919869] 1280x720p@50Hz. <4>[ 0.919890] 720x576p@50Hz. <4>[ 0.919909] 720x480p@60Hz. <4>[ 0.919928] Support audio type: LPCM
EDIT: This is debug11 turning on and off bt a few times (not working of course)
DMESG + GPIO
debug11_bt_test.txt
Notice the gpio busy on debug11
Code:<4>[ 2.361862] mt6622_probe. <4>[ 2.361889] mt6622 power_gpio is busy! <6>[ 2.361927] [MT6622] mt_bt_power_init
Code:<4>[ 880.868798] GPIO gpio3 278 BT_EINT <4>[ 880.868818] GPIO gpio3 279 BT_PWR_EN <4>[ 880.868844] GPIO gpio3 280 wifi_power <4>[ 880.868881] GPIO gpio3 281 wifi reset <4>[ 880.868913] GPIO gpio3 282 (null)
Code:<4>[ 135.244195] GPIO gpio3 278 (null) <4>[ 135.244200] GPIO gpio3 279 (null) <4>[ 135.244206] GPIO gpio3 280 wifi_power <4>[ 135.244212] GPIO gpio3 281 wifi reset <4>[ 135.244218] GPIO gpio3 282 BT_EINT
*** d33 please read last post on page 74!
Can someone else with Mediatek help out? I have to get ready for work... Or I can't afford to buy these magnificent toys
If you want to add GPIO dump to DMESG, use this:
gpio_rk3188_kernel_3.0.36+.zip
On a terminal, after decompressing files to sdcard, do this:
Code:su mount -o rw,remount /system cp /mnt/external_sd/user-gpio-drv.ko /system/lib/modules/ cp /mnt/external_sd/gpio /system/bin/ chmod 777 /system/bin/gpio
Code:su insmod /system/lib/modules/user-gpio-drv.ko gpio dump gpio dmesg > /mnt/external_sd/filename_of_dmesg.txt
Thanks!!!
Actually if you follow this thread it tells you how to discover the GPIOs by a combination of switching off/onLast edited by d33; 29 July 2014, 14:03.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Donate to Finless
Originally posted by Benobi View PostHi,
I will do that today.
Will send debug11 dmesg today later.
DMESG debug11: Not needed - it is for flickering onlyMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 3714 users online. 0 members and 3714 guests.
