Kitkat Kernels for All (well most!)
Tun and serial already in as are a lot of USB Ethernet. NTFS is in tooMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostTun and serial already in as are a lot of USB Ethernet. NTFS is in too
I think it's ready for release after you remove BT debugging then! :-) Great job d33! Glad I could help. I have a stripped CS928 rom (has same Wifi and BT) that Tech1 released, but it had too many files being installed included in the system.img so I stripped all those out and repartition the system.img to fit our sticks. I have all the installed apps as APK's in a .ZIP file if anybody is interested in them. Credit goes to Tech1 and developer that helped me! PM me if you want a copy. Not going to post public.
Yes, Great job D33 !!
Not sure if it is ROM or anything to do how Android is built, but any new app installed always goes to default memory space and I have to move it manually to SD card. Isn't there a way to control where these get installed? Also, isn't there a way to move these to "external_sd" card?Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by ghanashyaml View PostYes, Great job D33 !!
Not sure if it is ROM or anything to do how Android is built, but any new app installed always goes to default memory space and I have to move it manually to SD card. Isn't there a way to control where these get installed? Also, isn't there a way to move these to "external_sd" card?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
AFAIK it has 480P already?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostI've left some BT debug on :-/
Will upload another version tonight
BT / Wifi still works though?
[edit] ah I can see they do both work. I'll remove the debug tag and recompile. However there's no problem using these kernelsMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostRe-Download the files. I've removed the second debug flag
Im using kernel_KK_v4.2.5_TVSTICK_MT5931_HD.img
I checked and it does switches from 1080 to 720 to 576 and to 480.
I then have to run:
for 1080p:
Code:su wm size 1920x1080
Code:su wm size 1280x720
Code:su wm size 720x576
Code:su wm size 720x480
Is there a way to make it automatically set the wm size?
Donate to Finless
Originally posted by m4f1050 View PostCan you post link again? I re-downloaded and keep getting the BTHWCTL messages over and over..
Build date of today 13/08/2014Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by m4f1050 View PostDo you need dmesg and gpio while switching resolutions? It works for me....
1. It works
2. Debug is offMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 2602 users online. 0 members and 2602 guests.
