Kitkat Kernels for All (well most!)
    I hope my chip has not failed and will keep working for a while...
    I thought that maybe this cyxtech_cs918_8723_box_140731_8G2G kernel was not adapted to my cyx_V2.1 but to CYX_CS918 V2_3.
    So I downloaded another one reported to be a cyx_V2.1 kernel: cyxtech_rk31_cs918_8723_140509_8G2G 旧版.
    Seems that the problem was not related to the first rom :
    Code:
    <3>[    0.484456] i2c i2c-1: No ack, Maybe slave(addr: 0x5a) not exist or abnormal power-on, retry 2...
    <3>[    0.484754] i2c i2c-1: No ack, Maybe slave(addr: 0x5a) not exist or abnormal power-on, retry 1...
    <3>[    0.485051] i2c i2c-1: No ack, Maybe slave(addr: 0x5a) not exist or abnormal power-on, retry 0...
    <4>[    0.485111] The device is not act8846
    <4>[    0.485168] i2c-core: driver [act8846] using legacy suspend method
    <4>[    0.485211] i2c-core: driver [act8846] using legacy resume method
    See the full dmesg here : http://paste.ubuntu.com/8063530/
    I've readden that act8846 should be incoporated into the SOC... so it is normal if I could not see it on the board, right ?
    Is this bad doctor ?
    i gonna ask to other owners of this board if they can send their dmesg to know if it is a problem with all these board or only with mine.
    Cyxtech RK3188 box (cyx_cs918 v2_1) with last sock firmware and SPMC
    -> It finally works like a charm !
      ACT8846 is a discrete chip on the circuit board (quite small)
      The problem is then that there is no voltage regulation for the key services
      Code:
      [COLOR=#000000]<3>[    0.689507] DVFS ERR:    gpu can't get regulator in clk_enable_dvfs[/COLOR]
      <3>[    0.689550] DVFS ERR:    dvfs(gpu) is not register regulator
      <3>[    0.689595] DVFS ERR:    ddr can't get regulator in clk_enable_dvfs
      <3>[    0.689643] DVFS ERR:    cpu can't get regulator in clk_enable_dvfs
      [FONT=Verdana]<3>[    0.689692] DVFS ERR:    dvfs(cpu) is not register regulator[/FONT]
      So I think DDR will default to 300 Mhz
      NB. pulse h1102NL is ethernet chip (VMAC) - rtl8201F is transceiver
      Donate to Finless
        No, these are RK3188 kernels and only work with RK3188 ROMS.
        I'm creating a RK3066 TV Stick ROM for RK901/RK903 wifi, might see if I can also get it working for 8188 Realtek wifi. If you PM me your dmesg and GPIO dump I can see if I can make a kernel for your device(RTL8723) to make it work with my ROM, I'm going to release shortly.
        is there an easy way of doing this? or a link to somewhere that tells me?
        and thanks for the help... these sticks with the rtl chip are killing me and have caused me so much grief
          Follow my steps here
            I've re-organized the OP into individual WiFi support zips for smaller downloads and for easier replacement.
            Donate to Finless
              Thanks d33!
                Thanks d33 for your help.
                Can you please check if "WiFi Display" can be added too?
                  It's an option on the 3.10.0 kernel but I haven't discovered a loader that will allow 3.10 kernels to be flashed to RK3188 SoCs
                  Donate to Finless
                    cyx_cs918 v2_1 gpio dumps
                    Hi d33,
                    Even if my board may be damaged, I gess that GPIOs still the same.
                    As wifi and bluetooth are working with those "online stock kernels", you'll find attached my GPIO dumps and dmesg. gpio.zip
                    I tried to use agpio.py provided by Gin here but I'm not convinced by its reliability as I got different results depending on the order of switching ON and OFF... So I gess it's better for you to have a look on the files.
                    Many thanks for your work.
                    Code:
                    == w 0->1 ==
                    (209, 'RK30_PIN1_PC1')
                    == w 1->0 ==
                    (217, 'RK30_PIN1_PD1')
                    == b 0->1 ==
                    (224, 'RK30_PIN2_PA0')
                    (229, 'RK30_PIN2_PA5')
                    == b 1->0 ==
                    (249, 'RK30_PIN2_PD1')
                      I have a Q7 box (XT-Q7-V10)
                      It has the following chips
                      CPU: RK3188
                      WIFI: RTL8188
                      BT: MT6622
                      Can I just use the RTL8188 ones?
                        CPU: RK3188
                        WIFI: RTL8188
                        BT: MT6622
                        I'll build an Rtl8188/mt6622 variant if you will test
                        Donate to Finless
                          Ok, thank you
                            Hi d33, Hi mo123!
                            I understand dear guys that this thread is dedicated in general to kernels for 3188 based devices, but I would like to ask you for friendly help with making KK kernel for this beautiful CX818 box with 3066 onboard.
                            It has been lying on my shelf since I bought it last summer. It was only one attempt by dear neomode to make 4.2.2 custom ROM for this device, but I wouldn't say it was perfect, nevertheless I'm much grateful to him.
                            All chips are signed out by me on the picture and one only which is soldered on the back side of the PCB is USB2.0 hub GL850G by Genesys Logic.
Name:	CX-818 Front.jpg
                            If you are ready I would be glad to post dmesg or any another log you need for making proper config and compiling the KK kernel for testing.
                            Kind regards
                            CS918II/16GB(HTC-031-V1.0 board)
                            CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
                            K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
                              Ok, thank you
                              Test_1
                              Donate to Finless
                                Hello D33,
                                I try to install the new roms cr11s 20140710 with this the 4.2 kernel on my t428.
                                Bu i doesn't work.
                                Can you help me please?
                                Thanks a lot.
