Kitkat Kernels for All (well most!)
Donate to Finless
Hello d33. Tested your kernel http://www.freaktab.com/showthread.p...l=1#post229940 with stock firmware. The machine does not start. Connected to TV by HDMI and AV, no signal. What can do?
CYX_809III_RK3188 V2_1 20140208
Hi d33,
your kernel v4.2.5 with ESP8089 and MT6622 chip support works fine on CX919II clone with PCB version CYX_809III_RK3188 V2_1 20140208.
WiFi works. Bluetooth can pair with devices. Can I do some more testing to help you out?
Both SD and HD are functioning. But one small issue? in the HD version the CPU clock doesn't go above 1,4Ghz. SD version does go up to 1,6Ghz. Can I solve that with the Overclock-o-matic script in post #2 or do you need to correct something in HD kernel source?
Thanks in advance, and thank you very much for your work on the kernel!
It is the same source compiled in series so should be identical wrt cpuMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I run it at 1.4GHz with only a Heatsink and that heatsink gets pretty hot while watching a movie and running my Webcam, debating wether or not lower it to 1.2GHz now... (I use it as a monitoring device as well)...
Originally posted by BoBBes View PostI've mounted a heatsink as big as the CPU itself with a heigth of 4 cm. It gets warm, sometimes hot. I haven't tried it yet on 1080p while watching a movie of an hour. We'll see
Re: Kitkat Kernels for All (well most!)
Originally posted by mrdan View PostHi,
I already have this Android 4.4 : 4.4_T010_mtk5931_public_20140704.img on my mk809III with MTK WiFi
This work like a charm but this is a 720p kernel
How can I install your kernel in this android ? or do you have an other android 4.4 match with this kernel ?
cpu,gpu and ddr table
Originally posted by d33 View PostTo vary the T kernels for those that want to push to find their highest possible CPU potential you can can use the amended "Overclockomatic" perl script created by PHJAnderson. I've made a small alteration to make it compatible with KK.
KK Overclockomatic Script
Ive run the script on the your kernel: kernel_kk_v4.2.5_tvstick_ap6210_hd.img. The script executes as below and asks to identify the CPU,GPU and DDR. Could you help? How do I identify the CPU,GPU and DDR tables below/
C:\Oc>perl overclockomatic_kk.pl kernel_kk_v4.2.5_tvstick_ap6210_hd.img
Rockchip Patchomatic Suite
Overclockomatic RK3188 v1.2
by phjanderson
Reading kernel image
Done!
Searching GPU frequency limit cap
Found: 133000000, 600000000
Patching...
Searching volt/frequency tables
Done!
Volt/frequency tables found in the image:
== Table 1 at offset 10193664 ==
MHz mV
816 1000
== Table 2 at offset 10197328 ==
MHz mV
500 1100
== Table 3 at offset 10197352 ==
MHz mV
180 1150
300 1100
400 1150
500 1200
== Table 4 at offset 10197392 ==
MHz mV
200 1000
300 1050
400 1100
500 1150
600 1200
== Table 5 at offset 10197440 ==
MHz mV
816 1050
== Table 6 at offset 10207096 ==
MHz mV
504 925
816 1000
1008 1075
1200 1150
1416 1250
1608 1350
== Table 7 at offset 10207152 ==
MHz mV
200 1000
300 1050
400 1100
600 1250
== Table 8 at offset 10207192 ==
MHz mV
200 950 1 DDR_FREQ_SUSPEND
720 1225 256 DDR_FREQ_NORMAL
== End of tables ==
Please identify the CPU, GPU and DDR table. Press ctrl-c to cancel.
Which table is the CPU table?
(The CPU table is mostly the largest table ranging from 312 to 1608 MHz)
1080p @ 24 refresh rate support?
d33,
My device CS968 (WiFi-BT: MT5931SA-MT6622) still causes screen blank outs intermittently. I was thinking of testing out with the 1080p @24 refresh rate. However, I do not see that option in your kernel that I am using.
Kernel: kernel_KK_v4.2.5_TVBOX_MT5931_HD
Kernel zip: kernel_KK_v4.2.5_MT5931.zip
Is there a way I can add this as a supported refresh rate in the configuration somewhere or you will have to build a new kernel?
Thanks!Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
There are currently 2835 users online. 1 members and 2834 guests.
