Hi d33 / fellow users,
Thanks for the great work so far for the community.
I haven't had any response from Bob-Finless via private IM, so I am turning to help from d33 and public users... please help!
I have been trying to mod my MiniPC/TV stick recently with only limited success. My latest problem is trying to get NAND to mount. I've spend quite some time fiddling with CWM, TWRP, usb-otg issues but with no luck (details below).
My device: RK3188/T CX919II TV stick
ROM:
KitKat AP6210 Finless 2.0 ROM BETA (289 megs)
from Thread: NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
Scenario A
Kernel:
(default) kernel_stock
and also OC kernels from KitKat OverClocked kernel set (188 megs)
kernel_cpu1608h_gpustock400_ddrstock400
kernel_cpu1704h_gpustock400_ddrstock400
Problems:
Wifi doesn't work (not sure why)
CPU speed only goes to up 1.2GHz, even with OC kernels
Scenario B
So I tried kernels made by d33 from this thread:
Kitkat Kernels for All (well most!)
Version 3.0 kernels:
AP6210
AP6210-Alt (Alternative pinouts for some models like CX919-II, J22)
Success:
Wifi works
Problem:
Scenario C
4.2.5 kernels:
kernel_KK_v4.2.5_TVSTICK_AP6210-Alt_SD
kernel_KK_v4.2.5_TVSTICK_AP6210_SD
kernel_KK_v4.2.2_TVBOX_AP6210_SD
Success:
CPU speed goes up to 1.4GHz (everything feels 3x smoother, this is great!)
Wifi works fine
Problem:
"NAND flash" (SD Card internal) is now always unmounted (External SD Card is fine)
The pre-installed "Reboot" app from Finless ROM no longer works
I tried updating CWM - no luck.
Installed TWRP - I can see SD Card (internal) in Recovery Mode, I tried WIPING to format it, but still no luck. When I click on "NAND FLASH" in the "Explorer" app, it says "Internal Memory has been unmounted".
Ideally I would like to use Finless ROM, with NAND Flash (internal memory) Mounted, 1.4GHz CPU or faster, and Wifi working. Is this possible?
Could you please advise on how I can solve this problem?
Would you suggest another different ROM/kernel combo?
Your help will be much appreciated!
