Kitkat Kernels for All (well most!)
Thanks for uploading the source. (For ref: https://github.com/Dee-UK/D33_KK_Kernel)
Can you post the config you used for RK3188 + AP6330?
Originally posted by d33 View PostAdded ESP8089/MT6622 (MK809III) to the OP. Now working on fixing the CX-919II (J22) kernels
Originally posted by encore2097 View PostThanks for uploading the source. (For ref: https://github.com/Dee-UK/D33_KK_Kernel)
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by Linesguapo View PostI've tested in other flat, now the max resolution is 1920x1080p it is cool!
Is posible more OC a agresive OC
Mil gracias amigo
Donate to Finless
Originally posted by m4f1050 View PostHi d33, I tried this kernel but wifi was flickering on/off, and bluetooth did not work. I installed the MTK ROM and the wifi worked but no bluetooth. I read I have to use the stock 4.4 ROM for this? Let me know, thanks!
Sam321 has made a ROM that should work
Donate to Finless
Originally posted by d33 View PostOP updated with AP6210-alt (J22) kernels for tv sticks. Please test and report back with DMESG. I assume wifi works and BT doesn't
kernel_KK_v4.2.5_TVSTICK_AP6210-Alt_SD.txt <-- DMESGcx-919ii
Tried the kernel version RTL8723AU, on my CS918 box with RK6188T and RTL8723AS.
Stock ROM from http://pan.baidu.com/s/1bnB1Sf1.
All seems to work, except the 1080p which was my main reason to try a custom firmware.
I can set HDMI mode to 720 or 1080 it makes no visual difference.
I realize I was not rooted when I flashed.
Do I need root, SU and busybox for this to work?
Originally posted by Max One View PostYou are right. Wifi works BT doesnt.
[ATTACH]8180[/ATTACH] <-- DMESGMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Thanks! For anyone else needing them quickly: d33_KK_v.4.2.5_TVSTICK_AP6330_1080p+720p_defconfig.zip
There are currently 2497 users online. 1 members and 2496 guests.
