So far I'm trying to install dd33 kernel v4 with KK ROM by Veclinux
Kitkat Kernels for All (well most!)
Perhaps out of topic...but prior to play with different roms and kernels...how can I do a complete backup from my stock ROM? Any detailed guideline/tutorial?
I have a 809iii stock kitkat ROM with rtl8723bs chipset but I see bad WiFi performance (even good reception when no close to the router, bad or no transfer rate) and I wanted to change kernel to d33 one for this chipset
Enviado desde mi GT-I9300 mediante Tapatalk
Originally posted by ikerg View PostPerhaps out of topic...but prior to play with different roms and kernels...how can I do a complete backup from my stock ROM? Any detailed guideline/tutorial?
Re: Kitkat Kernels for All (well most!)
Originally posted by marko33 View PostDetailed info here thanks to Finless
http://www.freaktab.com/showthread.p...ew-RK-2-1-tool
Run the script in post #2
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
d33
My friend just bought a device with the ESP8089 + MT6622N chipset.
The ESP8089 kernel works fine without bluetooth, I haven't looked to see if the source is available for the bluetooth but if so can you please make a kernel if possible? no problem if not as he can live without it, but they may become more prevalent in the future. It may be a known issue bluetooth doesn't work and I have simply skipped over this information.
I currently have the device so can test if needs be.
Edit: Also if anyone is running the ESP8089 on 4.4 can you please tell me what ROM you're using? I am having major problems either A) getting 1080p to work or B) the wifi keeps turning itself on and off constantly.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
neomode rom 3.1 and d33 kernels
Do the d33 kernels work with the neomode 3.1 rom?
I have one of the MK809iii sticks with the ap6210 wifi that has the different gpio pins for turning the wifi on. And I can't seem to find a working rom/kernel combination.
My board is the one that says 2013-06-17 CXYTECH_RK3188_909 V1_1 with 8GB Flash and 2GB ram.
Any help would be appreciated.
HawkeyeLast edited by hawkeye; 10 September 2014, 23:23.
Originally posted by hawkeye View PostDo the d33 kernels work with the neomode 3.1 rom?
Hawkeye
I am very interested to know this...
Version 4.2.x
- TV Boxes - RK1000 support (Audio codec & TV out) / Dual lcdc
- TV Sticks - No codec / Single lcdc
- HD resolution (1920x1080)
- SD resolution (1280x720)
- Single kernel for all SOCs (this is overclock for RK3188T)
- CPU: 1.6 GHZ, GPU: 600 MHz, DDR: 720 MHz
- Increased PLL stability over v4.1
- Boots properly on MK902/CS968 models
- [Edit:] 4.2.2 Audio Fix for those without Audio on 4.2
- [Edit:] 4.2.4 Added ESP8089/MT7601/RTL8723AU^ support
- [Edit:] 4.2.4 Added support for RTL & MT6622 Bluetooth
- [Edit:] 4.2.5 Added MT5931 & RTL8723BS^ support
AP6210-Alt
Are these kernels (sd/hd) tested with a j22 tv stick? I m asking because none of them works on my cx-919ii.
No wi-fi and no bluetooth, dunno about LAN, i´m not using it.
D33, it would be nice if u could fix it. Thx in advance.cx-919ii
This is my problem also
AP6210-Alt
compile from source for CS968
Hello D33,
Firstly, thank you for your great work! I have a CS968 with MT5931/MT6622 need some new features so I try to compile the kernel from source. What I tried are,
- use defconfig (k3188_box_costdown_kitkat_defconfig, rk3188_box_pancake_kitkat_defconfig or rk3188_magicwand_kitkat_defconfig), change the CONFIG_MT5931=y, CONFIG_MT5931_MT6622=y, CONFIG_MTK_MT5931=y and CONFIG_RFKILL_RK is not set. I was able to compile the kernel.img and boot ok but the wifi and bt didn't work.
- use the config.425 rename to .config then compile, the kernel.img couldn't boot.
- I downloaded the kernel image you built at http://www.freak-tab.de/d33/kernel_KK_v4.2.5_MT5931.zip, it boots ok and both wifi, bt work!
- I pulled the config.gz from step 3, and use it to compile, didn't boot like step 2.
Please help, what I missed? I am really appreciated.
There are currently 2318 users online. 0 members and 2318 guests.
