Overclock it urself with overclockomatic. See the 2nd post of this thread.
Kitkat Kernels for All (well most!)
Originally posted by Max One View PostAll kernels are CPU: 1.6 GHZ, GPU: 600 MHz, DDR: 720 MHz
But what I really would like to know is if there are any differences between the following kernel files:
kernel_v4.1_TVSTICK_AP6210_HD ---->> kernel_v4.1_TVSTICK_AP6210-alt_HD
kernel_v4.1_TVSTICK_AP6210_SD ---->> kernel_v4.1_TVSTICK_AP6210-alt_SD
What are the real diferences between the called "alt" and normal kernels files?
Do you recommends to use the "alt" or the "normal" normal file in my CX-919?
Originally posted by ulises1954 View PostThanks Max One for your fast reply and info!
Do you recommends to use the "alt" or the "normal" normal file in my CX-919?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by Zonk View PostSay, d33 and noderat: am I correct in understanding that TV stick users with finless' beta2 rom cannot use the v4.x kernels yet? If so, would you expect a version for us might come out at some point or has a technical complication has arisen? Please do not construe this as a complaint, as I am more than happy with my stick's current performance, but one always does seek the latest and greatest.
The beta sources were released in January. I built T-override kernels from the beta kernel source (versions 1 to 3) and these worked with the beta source ROMs. I will not be building any more from these sources.
In April new sources were released by Rockchip. I have the kernel sources and am building t-override kernels with them (version 4). They work with the current ROMs on most models (MK902/A928/CS968 are exceptions)Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostI see Max1 has answered already but just to reinforce his reply; the 'alt' kernels are for those models that use a different GPIO to turn on/off the AP6210 wifi module. Most models use the 'normal' settings but there are a small number of models that use this alternate.
So the only difference is that:
"the 'alt' kernels are for those models that use a different GPIO to turn on/off the AP6210 wifi module"
I asked because both files apparently worked in my CX-919, so just want to be fully sure which one is better, before using this New 4.1 kernel...
Originally posted by ulises1954 View Post..both files worked in my CX-919
Your wifi should only work with one kernel, not both.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostIf both files work equally then something is wrong.
Scuse my mistake, what I meant was that both (the HD and SD) versions have worked flawlessly in my CX-919 with Neomode's 3.1 KitKat ROM...
I apologize again for the confusion and misinformation!
Originally posted by JugsteR View PostCould someone compile a list of ROMs which are compatible with the v4.x kernels? I know of Neomode v3.1, but that is it.
Signature? Signature!
Leolas is incorporating the 'override' code too so it may be best waiting for him to release his kernels.
He's using a 4.7 GCC version whilst I'm using 4.8.2. Perhaps that's the difference?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by noderat View PostHere's the full suite compressed up and ready for everybody. Interestingly enough they are actually smaller than d33's original zip (thank goodness for 7zip). Big thanks to d33 for his amazing work!
- v3.0 for TV Sticks Overclocked
- v3.1 for TV Boxes Overclocked
- v4.0 for TV Boxes Overclocked
- AP6210/AP6330/RT8188(VMAC) Fixed!
Preferably to be use with the CX-919 (FULL RK3188) whithout cooling...
I got sooooo frustrated I deleted the whole Ubuntu partition on my laptop!!
When I calmed down I reinstalled from scratch and .... it now works perfectly!
I'll upload a series soon but here is my AP6210 test file. I expect I'll have messed some stuff up in re-applying code but I'll get it all straightened out soon.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 1987 users online. 0 members and 1987 guests.
