Kitkat Kernels for All (well most!)
Originally posted by yever View PostHi, d33
On my MK908II, my webcam logitech C270 is very dark using the V4 kernel. I tried quite a few ROMs with the kernel, and all give me the same dark scene from my camera.
The only ROM that gives me the proper camera light is Bob's 1.6 for MK908II using Bob's kernel, but that's 4.2. I really like 4.4 ROM. If you can fix the camera light problem, that will be great. Thanks.
Originally posted by conftap View Posthow are you testing the webcam? on a finless 2.0 beta with v3.0 d33 kernel - the webcam turns on but I just get a blank screen when I try to use the USB Camera Trial app. Skype is audio only, no webcam.MK808B Plus, MK908II
Originally posted by conftap View Postyep, seems like it. don't think anyone's got kitkat usb webcam to work yet.
What i noticed is that there are patches for the logitech c270 from March. I wanted to give a 3.14 kernel a try to see if that changes things.
Are there any insights to why this is happening? Is this behavior a known issue for this kernel?
Regards
Jens
I'm using the generic UVC driver in my kernel builds. I'll have a look to see if the brightness is held within the driver.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by eldudarino View PostIs there something we can do? I have the same problem with the same cam model. Using a camera app i can modify the brigthness. This works for the camera app, the picture in skype stays pretty dark.
Regards
Jens
Originally posted by d33 View PostI'm using the generic UVC driver in my kernel builds. I'll have a look to see if the brightness is held within the driver.
Originally posted by conftap View Postatleast your cam works! what camera is it? and what rom/kernel combo? I've got a Logitech C310 and the camera app just hangs. I just got it to work a little bit by chmod 666 /dev/video0 and using dashcam.
If i'm not mistaken it is the vanilla image from RockChips for the 3188T
Great Job!!
The 4.0 last versions of D33 kernels are really great..
TV Stick (SD) AP6210 is working very good on Neomode 3.1 ... sometimes doesn't boot, but UI is fast and smooth... Antutu scores 19384 (i have an MK908II non T ver.)... connecting a wireless xbox controller was easy at first time.
The only problem was that kitkat can't recognize the 2Gbs of ram.. just 1.. but most hw info software can see all mem size.. Beyond XBMC playing most videos stuttering but Gotham version did all fine!!
Thanks a lot!!
From my recent start on this .. this was the most powered combo I found!
Tronsmart MK908II RK3188(non-T)
Originally posted by eldudarino View Postwell thats hard to tell, i just flashed it and now my girlfriend is watching some soap on it
Originally posted by carloscristo View PostThe 4.0 last versions of D33 kernels are really great..
The only problem was that kitkat can't recognize the 2Gbs of ram.. just 1.. but most hw info software can see all mem size...
There are currently 2188 users online. 0 members and 2188 guests.
