Kitkat Kernels for All (well most!)
I have a bug: i have a mk908ii and i ve installed that latest kitkat from april And everything is ok. But after i install the kernel from kernel_v4.00_TVBOX.zip i have a problem. I use on the otg a usb hub with 3 usb ports and a rj45 ethernet port. In 2 of the usb ports i have a logitech receiver for the mouse and a microsoft receiver for the keyboard. The microsoft receiver causes lag, mouse pointer movement lag, and reboots, but only if its in the hub, if i put it direct in the usb port from the mk908ii it ok. Same whit the xbox wireless receiver, system lags and reboots...
Re: Kitkat Kernels for All (well most!)
Originally posted by marca View PostI have a bug: i have a mk908ii and i ve installed that latest kitkat from april And everything is ok. But after i install the kernel from kernel_v4.00_TVBOX.zip i have a problem. I use on the otg a usb hub with 3 usb ports and a rj45 ethernet port. In 2 of the usb ports i have a logitech receiver for the mouse and a microsoft receiver for the keyboard. The microsoft receiver causes lag, mouse pointer movement lag, and reboots, but only if its in the hub, if i put it direct in the usb port from the mk908ii it ok. Same whit the xbox wireless receiver, system lags and reboots...
Originally posted by phyx1u5 View Posthi alljust wondering if anyone managed to get the camera for their tv sticks (if it has one) working with the d33 kernels? if so which did you flash? cheers
i have a microsoft lifecam hd 3000.
Originally posted by marca View Postmy camera is working with v4 kernel, the rom dosent have a camera app, but you could search google play for the new "google camera"
i have a microsoft lifecam hd 3000.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
good performance from the kernel, video playback is great.
bugs that i have:
1) when i power on the mk908ii it displays double the ugos logo... it loops (reboots i think) than a single logo ....and boots to desktop, then every things works ok.
2) screen scale is not remembered after power on or reboot
3) the bug with the keyboard and xbox wireless controller receivers (to work for me i changed the keyboard receiver in the otg cable and it dosent reboot there, and for the joystick i use a wired 360 controller in the same usb hub but dosent have the same reboot bug as the wireless receiver.
4) for the rooting part Kingo Android ROOT didnt work for me. vroot worked but is in Chinese. and i found another app called rootgenius and is in english and work good.
...hope some of this bugs will be fixed...
will keep testing. thank again d33 for your work.
Originally posted by d33 View Post#69 in this thread
Originally posted by marca View Postgood performance from the kernel, video playback is great.
I am using the ROM from post #69. It's a 720p kernel. After flash V4 1080p kernel, the icons become very small and the dock looks mis-aligned to me. How can I fix this?
Has anyone got recovery working? I flashed the recovery from kitkat 2.0 beta, but it does not work. I tried to reboot to recovery, I think it tried and gave up, then reboot normally.
EDIT: this is my first box. I am still trying to learn stuff here.MK808B Plus, MK908II
bugs that i have:
Originally posted by yever View PostAfter flash V4 1080p kernel, the icons become very small and the dock looks mis-aligned to me. .
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 3788 users online. 0 members and 3788 guests.
