Kitkat Kernels for All (well most!)
Originally posted by Max One View PostSry was to lazy to write those questions again =)Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View Post... and quite clearly too lazy to read the last few posts
Originally Posted by d33
I'm going to be much less active now unfortunately.
I've re-compiled the 'tester' kernels with GPU and GPU&DDR 'locked' - link in the OP. I can't test so let me know.
I've just seen there is source available for a linux 3.10 kernel, may have a look.
I just wanted to know if its possible to make a kernel (SD and, or HD) for a t version with default clocks 1.6 cpu / 720 ddr / 600 gpu??
ddr and gpu locked at 720 and 600.
SD TVBOX tester (AP6210, 1280x720) sd with density of 240dpi looks ******* huge. Wifi and BT not working for me.
This 1 has no ugos bootlogo and boot issue is gone.cx-919ii
Originally posted by Ploggy View Postcx-919ii
Originally posted by Max One View PostHere u will find the answer. http://www.freaktab.com/showthread.p...l=1#post170720
Thanks mate. I only ask because the one I posted a link to and the one these kernels are made from are different I think?
Originally posted by Max One View PostThats not true. I read them all.
ALL the 4.0 release kernels produced are clocked at 1.6/720/600, are HD res (1920x1080) and are for all SOC variants (T and original).
I produced a couple of 'tester' kernels for people who said these didn't boot so that they could test if re-locking GPU to GPLL frequency and/or limiting DDR to 450 MHZ worked for them (proving their SOC's couldn't work 'unlocked')
Today I responded to a request for SD (1280x720) kernel versions by producing a single test SD kernel for someone to confirm before I built the full series.Last edited by d33; 27 April 2014, 01:35.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Everything works well
No resets
Wifi OK
BT OK
Antutu 17500 - 18000Cozyswan S400 = KitKat_T010_AP6210_public_20140403 + kernel@d33_v4.1_TVSTICK_AP6210_HD
Originally posted by alan.w View PostEverything works well
No resets
Wifi OK
BT OK
Full series of SD created - see the OPMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Donate to Finless
Originally posted by d33 View PostI'm going to be much less active now unfortunately.
For me, no logo and no boot with kernel_kk_4.0_noGPU
Originally posted by d33 View PostFull series of SD created - see the OP
My User Interface (menu, transitions, etc) looks smooth & faster.
Benchmark 17700!
Is it possible to make Overclocked versions of them?
Greetings.
Hi All,
I did a complete test to my stick and i found these...
Everything was tested with Geekbuying latest Android KK firmware:At stock works fine.
With 2.7 kernels everything is fine.
With 3.xx i can`t even boot.
With 4 kernels i can`t boot.
With 4 kernel no GPU, stick boots, i can see ugoos logo for a split second, an then i get parallel white lines distorted.
With 4 kernel no GPU and no DDR, i get the ugoos logo and stuck at this.
I have the MK802IV from rikomagic.
Any advise would be grateful. Everything i try with kernel that have the gpu or ddr unlocked isn`t working for me. The cpu works well with o/c till 1.9mhz, but i can`t use any unlocked kernel, not even the no gpu no ddr one.
What rom?Mk802IV Neomode 1.9a original rom 720p
There are currently 2863 users online. 1 members and 2862 guests.
