Kitkat Kernels for All (well most!)
Originally posted by wichoxp View PostHow much voltage (mV) is safe to put in cpu-freq table?...
Is it safe to put a greater voltage than 1450mV? (let's say 1500mV or beyond) without frying your dongle?
Greetings.
- FACTORY TABLE (Rockchip) goes to 1350mv MAX
- OVERCLOCK TABLE (pjanderson) goes to 1450mv MAX (+7%)
Is it safe to increase pjanderson OC'ed mV table?... How much can it be?
Greetings.
Originally posted by Pihkal View PostYou're welcome, glad to hear it's useful for some people.
I've never tested overclocking without extra cooling on my stick.
As you can see I have a rather big heatsink on my RAM and SoC:
Even with this mod I sometimes don't feel completely comfortable with my temps.
I wouldn't go over 1600/600/720 without extra cooling, but that's just paranoid old me.
I'm running at 1800/600/720, pushing the GPU past 600 Mhz makes little to no difference on performance but makes a huge difference on the amount of heat generated by the SoC.
At least that's the case with me but I have a T-SoC.
Regards
I decided to install the following OC Kernel:
cpu1704/gpu600(stock)/ddr667
As Neomode's already have suggested, and just to be fully sure that my CX-919 don't over heat...
And I am getting an ANTUTU = 19,300 to 19,450 !!
As I mentioned before my CX-919 have the FULL RK3188 (Not T), and I am using it without any Cooling...
Does anyone here in the forum have tested the CX-919 with a higher speed kernel without over heating problems and have got better performance?
i am facing strange issue with kernel 4 and 4.1 after installing the kernel i see nand is not mounted. so basically i cant access any of my application. however if i reinstall kernel 3.1 everything is working fine. can anyone explain me what could be going wrong?
i am using cx919 rk3188(without T).
Re: Kitkat Kernels for All (well most!)
EDIT : Pulled picture linksLast edited by mechaone; 11 May 2014, 08:17.Please post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Strange issue started today
D33 (or anybody else),
Till evening, my CS968 was all fine, with fullscreen 1980x1080p. At night when I turned it on, it showed up as probably a 4:3 aspect ratio. With wm, I checked that the size and density were 1920x1080 and 240 indeed. Tried almost 10 times and all settings I could think of and also the screen scaling (seems to be at max for width.)
My ROM is htc_t018_public_MTK_root_CSQ_4.4.2_20140424 and kernel is kernel_KK_v4.21_TVBOX_AP6210_SD.
Do you know how to rectify this? I have attached DMESG and screen images (I had to reduce density to 160 to get the fullscreen shot displaying information. Rename the screen information files to .jpg, as I was facing problems with image uploads.)Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Excuse me trolling in this thread, but I need your help. Some people (and me too) couldn't get the Chuwi v88 quad tabs above 1.4GHz under KK. (Under JB it goes well on 1.6GHz)
So I flashed v5.3 JB ROM, v2.2 and v2.3 KK ROMs with JB kernel, and v3.1 KK ROM with KK kernels and dmesged the tablet.
So I ask you to take a look in the result with your most experienced eyes and tell me the possible problem with our devices.
Thank you,
Working kernels 1080p on MK802IV New WiFi
Guys,
Tried everything I know, but I could not make D33 kernels working on my MK802IV New Wifi.
I started with Finless Rom 2.0, changed boot.img to patched 1080p, everything working well with »strock« kernel made by Bob until I rebooted.
Tried Neomode 3.1, everything works well with Neo's »stock« but it is 720p. Youtube stays there at 720p does not matter what you stream from them.
As far as I try D33 any kernel, 4.1, 4.0, 3.0 anything, my stick will not boot. It blanked shortly and then I have no signal on my television.
Can somebody help me to do it if it is possible. What I want is KitKat ROM and 1080p kernel with or without OC, just working 1080p on MK802IV New Wifi.
Thank you.
same problem here !
I have exactly the same problem , now stick with Neomode 3.1 and his 1.6Ghz OC kernel.
I do have problems with full screen video on this rom.
So I'd love D33 his 4.0 kernels to work on this rom .
bye.
Thank you.
Thank you.
D33 please help... I need to unlock my ******* T crap cpu!!!!!
Originally posted by babnik80 View PostI have the same stick and i can`t get it to work with any kernel rather than the 2.xx. With any other d33 kernel i get blank screen and no boot.
As for Kitkat 4.4.2, any of them seem to work pretty well including wasser 0.95, SMIC17394 V2, cloudnet, etc.. Some need tweak of buildprop density set to 200, 220 or 240 on 1080p based on personal preference.
Bootloader version?
Thank you.
Hi...
I had this problem a few weeks ago... so try this.
Change the bootloader (i think it's 1.0something )... the 2.08 version, that came with the finless kitkat 2.0 resolved the problem to me.. use this new bootloader and flash mk again..
Hope to help U!!
PS. Sometimes it not boot at first time... but on second or third, it goes... i think it's related to PSU maybe.Tronsmart MK908II RK3188(non-T)
There are currently 1797 users online. 2 members and 1795 guests.
