Kitkat Kernels for All (well most!)
Kitkat Kernel for QX1
Hi All
Can anyone suggest which of these kernels I could try on my QX1 ?
I've loaded the kitkat finless ROM for the QX2 and it works really well except I have no WIFI or BT.
I'm ok without WIFI or BT but if one of these works then I can try it and see if it helps anyone else out.
Cheers
Originally posted by ghanashyaml View PostD33 (or anybody else),
Till evening, my CS968 was all fine, with fullscreen 1980x1080p. At night when I turned it on, it showed up as probably a 4:3 aspect ratio. With wm, I checked that the size and density were 1920x1080 and 240 indeed. Tried almost 10 times and all settings I could think of and also the screen scaling (seems to be at max for width.)
On a side note, I do see an infrequent boot issue and an issue where it is not turning on when TV is turned on.Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by ynot123 View PostIf you want to make the MK802IV 1080P work with D33 kernels later than 2.07 then the only working one is likely this tester kernel with no DDR or GPU OC. Download link is
As for Kitkat 4.4.2, any of them seem to work pretty well including wasser 0.95, SMIC17394 V2, cloudnet, etc.. Some need tweak of buildprop density set to 200, 220 or 240 on 1080p based on personal preference.
Have you found any explanation why this is the only kernel that works with our fu...ing sticks. All others work great with the unlocked frequencies for the gpu and ddr.
D33 do you have any idea why is this happening?
Cheers
http://www.freaktab.com/showthread.p...Imito-QX2-BETA
D33 getting 18000 at 1.4 with your kernel and smic build wow , everything working just loading video files and tests but running very fast with no oc yet,mk902 working cool and sweet,
no 5.1 on hdmi video smooth and running fine ntfs files found played, bluetooth netwok wifi all working, camera ok led blue lighton steady. great kernel.
going to try libmedia.so hack to see if helps 5.1 in beyond?
edit random reboot and crashes when running in beyond, task bar disappeared and woulnt come back no matter what i tried reflashed again same issues after about 20 minutes.Last edited by scooter2014; 14 May 2014, 14:31.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
OC'ed GPU-DDR to 768Mhz for picky/fragile dongles
Hello. I want to share my custom overclockomatic patch for dongles with OC issues.
It has been modified to support low voltages instead default ones (1.35volts MAX).
Also, freq values have been lowered a bit (798 to 768Mhz) to support hard tests:
[Download link]
For newbies: in order to make this work, you need to install Perl [download] Once installed, go to cmd and type:
perl [drag&drop perl script.pl file] [drag&drop d33 kernel.img file] (press Enter)
Some tables will appear. After that, type 6 (for CPU), 7 (for GPU) and 8 (for DDR)
Wait some secs and voilá!
Greetingz.Last edited by wichoxp; 14 May 2014, 19:28.
D33 or anyone else,
Iam running cs968 MTK chipset with KitKat MTK 20140424 (Tech1 modded).
I am running XBMCZ and I am looking for the best configuration to run on this Device with KitKat and XBMC (any version whoever works best in combination with KitKat & hardware cs968). Could these kernals solve the challenge that I have?
I am also very new to kernels and how to flash new kernels, I have flashed ROM:s, rooted etc, but how do you flash/load new kernels?
Pejochto via TapatalkCR11S AP6210 Chipset
CS968 MTK Chipset MT5981 - MT6622
HTC-T018-V04
Originally posted by wichoxp View PostHello. I want to share my custom overclockomatic patch for dongles with OC issues.
[Download link]
Greetingz.
This will probably help a good number of people.
Kudos!
Regards.
Originally posted by Dzigi.Bau View PostWe MK802IV New WiFi users, kindly ask D33 to make more stable kernel for us, overclocked or now, does not matter. This tester build 4.0 is good, but has some bugs. Sound flickers.
I got two new MK802IV and they both have no sound issues with D33 kernels.Mk802IV Neomode 1.9a original rom 720p
There are currently 2114 users online. 2 members and 2112 guests.
