Kitkat Kernels for All (well most!)
Re: Kitkat Kernels for All (well most!)
Originally posted by d33 View PostPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Hello,
Excuse my "noob" question, but i have a T428 tv stick with T428 KitKat Finless ROM 2.0, and when i flash a kernel more than 3.0, i cannot access to my nand memory space (first 2go partition systeme and micro sd space is ok).
I do flash the 3.0 version to access to the nand memory space again.
After a reboot, when i go immidiatly in "stockage" i can see the nand but it Disappear after few secondes.
Can you hep me please ?
Thanks a lot.
PS : excuse my poor englishLast edited by jason.v59; 26 May 2014, 07:42.
Originally posted by dogmangame View PostI have a mk809III RT8188ETV wifi and every kernel i have tried from d33 has a no signal on the tvI also tried noderat over clock kernel as well with no success i have managed to get 4.4.2 to work with Yerzu kernel do any of your kernels work for MK809III Old Wifi series? I would love to have some possiblities to OC alittle on my device with KitKat and you seem to have the kernel needed I would deeply appreciate if your could maybe make a test kernel for my device or anything from your series of kernels would help thanks for your hard work making these kernel possible
EDIT: Seems that the 4.2 release doesn't contain a CPUONLY img anymore. Was this intentional, and is it supposed to work?Last edited by HomerSp; 26 May 2014, 08:40.
Originally posted by mechaone View PostWhat is the end effect difference between -T and non-T chips?
Originally posted by mechaone View PostAm I correct in the assumption this last kernel build is tailored specifically to the "purebred" 3188?
The whole point of this exercise was to make a fully normal kernel for T SOCs that could perform at 'standard' speeds (1.6 GHz CPU & 600 GPU).Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Thanks a lot.
ROM based on beta sources-> kernels based on beta sources (2.x, 3.x)
New 'official' ROM -> new kernel (4.x)Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by HomerSp View PostTry the AP6210 CPUONLY img, if it boots I can upload a CPUONLY build for the RLT8188 (no, I don't have the source, it's' a hex edit). Like d33 and a few others discussed before some of these sticks don't like DDR and GPU OC, so you will, unfortunately, have to use a kernel where you can only OC the CPU.
EDIT: Seems that the 4.2 release doesn't contain a CPUONLY img anymore. Was this intentional, and is it supposed to work?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by EzerchE View PostHello D33, i there MK908 v3 support will be in future?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostMake/models mean nothing to me. Just find out what wifi chipset it uses and what type of device it is; stick/box.
(This) firmware's kernel boots, and works, but it has serious hdmi problems, if i shut down the TV and then open again, screen becomes this:
Apologies, D33. My bad.... Although you've now answered my question, I was intent to ask "What is the end effect difference between -T and non-T chips (when using the latest PLL tweaked kernel)?"
Im finally going KK this week. 'Bout time, too.
Thanks again, D33. You da man, Man. Best of luck in the future with the 3288 and anything else ya put yourself to.Please post your h/w & s/w as signature to help community with troubleshooting problems.
Originally posted by mechaone View Post"What is the end effect difference between -T and non-T chips (when using the latest PLL tweaked kernel)?"Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 2054 users online. 0 members and 2054 guests.
