.gif)
Kitkat Kernels for All (well most!)
Originally posted by Max One View PostThx a lot. Works like a charm.
Sry D33, we need another fixed kernel, please.
Btw same reboot issue on both kernels SD and HD.
Back on Kernel 4.1 for now.
Thx in advance.
Max1cx-919ii
Originally posted by Max One View PostOk the wifi of the fixed 4.2 kernel works now like a charm but the reboot issue is back. The first released 4.2 kernel for Tv Sticks doesnt have the reboot issue. Ive tested the 1st released kernel and the fixed some min ago and they are different. The fixed 4.2 Kernel will not reboot immediately.
Thx in advance.
Max1
Re download?
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by digger View PostHi d33,
Any chance to have V4.2 RTL8188 VMAC HD kernel for boxes?
It needs more time than I have. Leolas may have solved.
Donate to Finless
Originally posted by d33 View PostWhen I addVMAC it fails to boot. When I amend the code it screws up the GPLL clock.
I would be happy to use your beautiful 4.0 VMAC kernel, if it didn't have problem with losing Ethernet connection after waking up from slipping mode. Difficulty with boot isn't the first problem(power consumtion is low enough so as to think about power economy, I hope GreenPeace forgives me
I had already asked Leolas but their Nitro team doesn't have compatible hardware to test, so he refused me.
Don't worry, please. You already did a lot for me and I'm so grateful to you.
I'm shure you'll be visited by some bright idea once when you have more time.
Thanks and have a nice eveningCS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
USB Cam support?
Hi d33,
Thanks for your work on these kernels. Just have one quick question for you, do any of these kernels have USB cam support?
My TV STick is AP6210 Alt (J22/GM282/CX-919ii) and I am running official kitkat rom 20140403 with a Logitech QuickCam for Notebooks Pro (V-UAR38) usb cam. The audio input from the cam built-in mic works fine in skype, but the image/video is very DARK or useless in Skype. Seems like Auto White Balance not working, and I assume that's the driver built-in Kernel that needs to be fixed?
Any comment would be greatly appreciated!!!
Originally posted by d33 View PostThe following are kernels built against Rockchip sources provided to Freaktab on condition we don't publish (sorry!). These are intended to be used with the recent release of "official" ROMS (April 2014 onward) not beta ROMs (use v2.x/3.x for these)
Version 4.2- TV Boxes - RK1000 support (Audio codec & TV out) / Dual lcdc
- TV Sticks - No codec / Single lcdc
- HD resolution (1920x1080)
- SD resolution (1280x720)
- Single kernel for all SOCs (this is overclock for RK3188T)
- CPU: 1.6 GHZ, GPU: 600 MHz, DDR: 720 MHz
- Increased PLL stability over v4.1
- Boots properly on MK902/CS968 models
TV Stick pack (AP6210/AP6210-alt/AP6330/RTL8188)
Version 4.1- TV Boxes - RK1000 support (Audio codec & TV out) / Dual lcdc
- Increased stability over v4.0
TV Stick pack (AP6210/AP6210-alt/AP6330)
Version 4.0
AP6210/AP6330/RTL8188(VMAC) --> TV Boxes (HD)
AP210/AP6210-alt/AP6330 --> TV Stick (HD)
AP6210/AP6330/MK7601/RTL8188(VMAC) --> TV Boxes (SD)
AP210/AP6210-alt/AP6330 --> TV Stick (SD)
If you want higher overclocked kernels Noderat has kindly uploaded here
Older Kernels created from the "BETA" Sources (January 2014) for use only with the 'Beta' ROMS prior to April 2014
I've taken the stock source, which has code to switch between T and non-T CPUs and converted it to make two dedicated kernels. Github here
Version 3.1- RK1000 Audio support fixed
- RK100 TV out support added
- GPU overide for T kernels now possible (450 limit removed)
- DDR override fixed (PLL limit to 445 removed)
AP6210
AP6210-alt (Alternative pinout)
AP6330
RTL8188 (3.11a)
MT7601 (wifi only) test
TV Sticks
AP6210
AP6210-Alt (Alternative pinouts for some models like CX919-II, J22)
AP6330
RTL8188EU
NODERAT has been a superstar and generated a massive number of overclocking variants for all these core kernel builds -> see here
Donate to Finless
Thanks for the confirmation, now I know it's not about specific Cam, but the kernel driver general support itself is buggy.
Is this thing fixable by Dev or it has to be fixed by Rockchip since they have the source code and it's not open to public?
Thanks!
Originally posted by d33 View PostKernel has AvC webcam support but dark video a known bug
CR11S AP6210 5Mpx Camera - Reebot/Restart
I tried to install the newest stockrom from Cloudnet 20140526 KitKat and then flash one of the kernels here for TK3188 AP6210 HD, The box gets into a loop and resets itself. Sometimes the boot goes on to the homescreen and restart and sometimes during the bootup.
Are theese Kernels not for my Box?
Originally posted by tomguide View PostThanks for the confirmation, now I know it's not about specific Cam, but the kernel driver general support itself is buggy.
Thanks!CR11S AP6210 Chipset
CS968 MTK Chipset MT5981 - MT6622
HTC-T018-V04
Thanks!
You can also change the sensitivity and whiteness level among other things, but it's extremely complicated and in Chinese.
If anyone wants more information I can send the file if you are a kernel developer.
No matter what I do the CPU is still 312 - 1412 ?
I think I am going crazy in trying to overclock my KitKat Stockrom 20140526 CR11S AP6210.
Everything seems to go well and your Kitkat modified perlscript, I even got more Tables when i run your script, with the other script I didnt get the tables of DDR memory.
But when I path the kernel with the outcoming files, NOTHING happens, everything is reset to normal, all Cpu values are still the same. 312-1412 Ghz , I thought this patch and script should do it with the KitKat Roms, Why doesn it work. I tried Quickshot Rom 3.1 and then i get overclocked CPU, but why doesnt this do it? Even if I have a RK3188T chip, this would do it, right?
PLease help me with this, my wife is going to throw me out soon if she see more reboot and patching
Originally posted by d33 View PostTo vary the T kernels for those that want to push to find their highest possible CPU potential you can can use the amended "Overclockomatic" perl script created by PHJAnderson. I've made a small alteration to make it compatible with KK.
KK Overclockomatic ScriptCR11S AP6210 Chipset
HTC-T018-V04
Originally posted by pejochto View PostI think I am going crazy in trying to overclock my KitKat Stockrom 20140526 CR11S AP6210.
Thanks for your answer, I actually read almost the whole thread after i posted the question. But I tried to patch d33's kernel for RK3188 Ap6210 4.2 but i got into a unstable mode, the box rebooted sometimes on startup and sometimes when started up, no pattern?
Which kernel should I use for the CR11S stock rom?
I have a 5mpx camera.
All the posts where I found interesting links to roms to try out is no longer active?
I cant find any kernels for rk3188T models that are mentioned in this thread.
So IMHO its not that easy to follow up a thread with this many posts and try to understand and learn while you reading. :-)
Sent from my iPhone using TapatalkCR11S AP6210 Chipset
HTC-T018-V04
Originally posted by pejochto View PostThanks for your answer, I actually read almost the whole thread after i posted the question. But I tried to patch d33's kernel for RK3188 Ap6210 4.2 but i got into a unstable mode, the box rebooted sometimes on startup and sometimes when started up, no pattern?
What I can tell you is that all kernels here are compliled by d33 for 3188T devices but not for 3188.
Concerning the removed links I think these kernels inside the thread were removed by d33 bacause they were uploaded by him for testing purpose only before he releases some stable version.
I use 1704/798/800 OCed V4.0 kernel for my device and it has good stability, but some people here noticed that some definite 3188T chips hate GPU overclocking. So if you have 3188T onboard, try to test OC kernel where GPU clock is not higher than 600. Probably it'll solve your problem with rebooting.CS918II/16GB(HTC-031-V1.0 board)
There are currently 2565 users online. 2 members and 2563 guests.
