Kitkat Kernels for All (well most!)
Originally posted by Finless View PostDonations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
Originally posted by walter77 View PostTested kernel on CX921b, fresh installed KitKat_T010_AP6210_public_20140403 ROM, powered with usb hub. Everything seems to work, wifi, lan, bt.
Antutu scored 19609 at first run, 19998 at second and 19921 at third!
I do not see how your getting sound with this combo on the 921b?
I just tried the latest rad-xa ROM which is RK1000 and I get no sound either.
There is something wrong with the kernel sources and some kind of compatibility with different TVs!
It's got to be something like that. I have 2 of these 921b's and BOTH don't give sound.
Again the point here is without flashing anything else, if I flash back to D33's 3.1 kernel I get sound!
WTF
Originally posted by Finless View PostWalter, this kernel kernel_KK_v4.21_TVBOX_AP6210_SD.img and the T010 ROM do not list RK1000 in the devices manager. It lists only HDMI-I2S.
BobDonations are welcome and will be shared with other devs:
DONATIONS
D33, I also tried the CloudGo C11s ROM and it is also RK1000. I still get no sound!
But yet again... if I flash your old 3.1 kernel I get sound.
Something is up and I just do not know what!
No other BOX that I have has this problem. Only the 921b. Since I have 2 I know this is not a hardware issue.
Remind me what other box's have RK1000?
Originally posted by ulises1954 View PostThanks for your detailing information!
For all that you have mentioned, I am stating to believe that Nomode's have suggested to use, to be safe without cooling, and avoid Over_Heat: cpu1704h - gpustock - ddr667
But how about raise a little the ddr from 667 to 720, Do think it will make some difference on performance without generating such a big amount of heat?
Thanks again for all your help!
But keep in mind a higher freq also means slower timings, in other words: a higher clock doesn't always mean faster ram speeds.
It increases the bandwidth, but not the throughput...
About SoC freqs vs temps:
Ik would say 1700 Mhz CAN be safe but remember the ARM doesn't normally run flat out at 1700 Mhz all the time, It tries to run at the lowest possible speed and throttles up when needed.
The CPU governor decides when this happens.
If you however run your CPU at 1700 Mhz all the time It will most likely overheat and become unstable at best or even fry.
Try It at your own risk... I wouldn't but you can do whatever you want with your device.
Just my 2 cents.
Regards
Originally posted by Sarco View PostRadxa has RK1000. Passtrought available in JB and KK.
Basically I have tried everything I can think of. There appears to be some compatibility issue with sound and my two LG's with these kernel sources!
I think I have another box here with RK1000 audio chip but so far I have not found which it is. I want to see if this is a 921b problem only or with other RK1000 devices.
BobT428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Thanks for the help but I have tried all the sound settings even the basic RK_29_RK1000 out.
No sound what so ever!
My MK902 has RK1000 so I am going to try that box and see what I get.
Originally posted by Finless View PostThanks for the help but I have tried all the sound settings even the basic RK_29_RK1000 out.
Greetings.
OK I get audio on my MK902 with RK1000. So this is ONLY an issue on my 921b!
D33, something is different with this box. When you say your getting audio are you using your 921b from AndroidTV?
FYI been using the same HDMI cable on all boxes. So it's not cables or anything else.
There are currently 1820 users online. 3 members and 1817 guests.
