Kitkat Kernels for All (well most!)
    OKUOTE=tinyhands;159752]Quasi-Success: I had been using a newer binary, 5.18.1 (sub 2 is also available). I uninstalled it and have now installed 5.16.3.
    I'm now seeing the table contents and they match the guidance from the script, but I get an error at the end.
    Code:
    D:\MK908ii\RKPatchomatic>perl d33revisedoverclockomatic3188 kernel_t_AP6210_HD_v207.img
    Rockchip Patchomatic Suite
    Overclockomatic RK3188 v1.2
    by phjanderson
    Reading kernel image
    Done!
    Searching GPU frequency limit cap
    Found: 133000000, 600000000
    Patching...
    Searching volt/frequency tables
    Done!
    Volt/frequency tables found in the image:
    == Table 1 at offset 9947136 ==
    MHz     mV
    816     1000
    == Table 2 at offset 9950800 ==
    MHz     mV
    500     1100
    == Table 3 at offset 9950824 ==
    MHz     mV
    180     1150
    300     1100
    400     1150
    500     1200
    == Table 4 at offset 9950864 ==
    MHz     mV
    200     1000
    300     1050
    400     1100
    500     1150
    600     1200
    == Table 5 at offset 9950912 ==
    MHz     mV
    816     1050
    == Table 6 at offset 9952952 ==
    MHz     mV
    312     900
    504     925
    816     1000
    1008    1075
    1200    1200
    1416    1250
    == Table 7 at offset 9953008 ==
    MHz     mV
    133     975
    200     1000
    266     1025
    300     1050
    400     1100
    600     1250
    == Table 8 at offset 9953064 ==
    MHz     mV
    200     950     1 DDR_FREQ_SUSPEND
    528     1250    256 DDR_FREQ_NORMAL
    == End of tables ==
    Please identify the CPU, GPU and DDR table. Press ctrl-c to cancel.
    Which table is the CPU table?
    (The CPU table is mostly the largest table ranging from 312 to 1608 MHz)
    6
    Which table is the GPU table?
    (The GPU table is mostly the second largest table ranging from 133 to 600 MHz)
    7
    Which table is the DDR table?
    (The DDR table is mostly quite short, mostly 2 entries, and can be recognized by
     the labels DDR_FREQ_... at the end of each line)
    8
    Patching kernels... please wait...
    ERROR: DDR profile table ddr667 is larger than the DDR table in the kernel
    Next?[/QUOTE]
    OK downloaded and installed , ran Perl again same but then I seen It was wrong kernel not kk so switched loaded and ran so now I start taking apart again as no boot.
    Ok
      rkpatchomatic_kk d33 full suite
      I just built the full rkpatchomatic suite and I'll be uploading and editing this post with the links as they finish to save everybody a little time. These include all available variations made by rkpatchomatic. Each archive is about 3.5MB
      Latest Overclocked Version Here
      Only after you've donated to Finless and Neomode are you allowed to donate here.
        EDIT: First batch finished uploading:
        AP6210
        kernel_AP6210_HD_v207 - http://adf.ly/hO2hE
        kernel_AP6210_SD_v207 - http://adf.ly/hOMiB
        kernel_t_AP6210_SD_v207 - http://adf.ly/hONOO
        kernel_t_AP6210_HD_v207 - http://adf.ly/hOBzq
        AP6330
        kernel_AP6330_HD_v207 - http://adf.ly/hOU6l
        kernel_AP6330_SD_v207 - http://adf.ly/hOVTK
        kernel_t_AP6330_HD_v207 -
        kernel_t_AP6330_SD_v207 -
        i am getting an error when trying to open kernel_AP6210_SD_v207. could you please re-upload kernel_AP6210_SD_v207 file.
        Update: I tried HD kernel version it boots up properly everything works except i had only one issue i keep getting safe to remove drive message in the notification bar. it goes on and off basically i cant access by USB flash drive it comes on and go off. No such issue with kernel version 1.1. everything works well and i can access USB flash drive without any issue. Not sure what is problem with Kernel version 2.7
          Originally posted by d33 View Post
          Incidentally, forum member Billgatos has tested ethernet and says it isnt working as the ROM doesn't specify a MAC Address. Would appreciate feedback on this from others
          Anybody figure out a way to specify the mac address?
            I managed to set the mac address manually by using commands in a terminal emulator
            su
            ip link set eth0 address [your desired MAC address]
            ifconfig eth0 up
            Although I got an error on the set eth0 command but the MAC address was actually set.
            See attached screenshot. Ethernet is working.
            Perhaps we can put something similar in a script file ( init.d ?)
            Regards,
            hkp168
              Test for MK7601 (wifi only) file offline
              hackadroid tested MT7601 here - http://www.sendspace.com/file/e38rak dmesg
              Still no wifi or BT.
              Will also upload my dmesg tomorrow, looks different.
                That isn't a v207 kernel, and I didn't try to get BT working as mt6622 code is not compiling properly.
                [edit] ahh I just reread and realise I didn't recompile at 207 !
                Using my ipad so apols for any stupid ios spelling 'corrections'
                Donate to Finless
                  Great success (Borat voice)
                  Hi everybody!
                  I just want to confirm that the AP6210_HD_v207 -Kernel works good for my CX-919 (non-T):
                  + 1.8GHz
                  + 1080P
                  + 22096 Atuntu score
                  - Bluetooth is significantly weaker than stock rom
                  Isn't the CX-919 capable of b/g/n? Mine only shows up as 54Mbps (meaning 'g').
                  Here is a bonus picture of my cooling mod with internally soldered fan:
                    EDIT: Google drive botched the upload. These links have been fixed.
                    AP6210
                    AP6330
                    kernel_t_AP6330_HD_v207 - http://adf.ly/hOkxm
                    kernel_t_AP6330_SD_v207 - http://adf.ly/hOlJg
                    Having issues with Google Drive uploading the others, will try to finish tomorrow.
                    Hey Noderat,
                    I've tried your patched kernel_t_AP6210_SDv207 but is has the excact same issue as the one I've patched myself.
                    Flashed cpu@1800, GPU@stock and RAM@720 and the RAM OC just doesn't work:
                    Code:
                    root@m0:/mnt/internal_sd # dmesg | grep ddrfreq
                    <6>[    2.059606] ddrfreq: verion 3.2 20130917
                    <6>[    2.059640] ddrfreq: fix cpu pause bug
                    <6>[    2.059676] ddrfreq: normal 720MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 222MHz
                    <6>[    2.109628] ddrfreq: change freq to 445 MHz when normal
                    See, it sets the RAM to 720Mhz and backs down to 445Mhz...
                    There's no difference in memory performance or overall performance so clearly there must be something wrong...
                    Greets
                      Search DMESG for d33info and post the flag values
                      Donate to Finless
                        Ok - fixed GPU override and second DDR overide but this removes some protection so flash at own risk
                        v208-t - (HD, 1.4 GHz, 600 GPU, 528 DDR) I'll tidy up and release properly if this works for all
                        v208-full - (HD, 1.6 GHz, 600 GPU, 720 DDR) Antutu 19,000 with Finless A928 ROM on CX921b TV Box (Rk3188T CPU)
                        Donate to Finless
                          i see most of them have successfully installed kernel. however i am having an issue when installing the kernal i keep getting message "select keyboard layout" and my external sd card and usb storage keep getting unmount. i am using AP6210_HD_v207 Kernel for my CX-919 (non-T) version.
                          i dont see any such issue when installing bob's stock kernel. can anyone help me with ap6210_hd_v207 kernel?
                            AW: Kitkat Kernels for All (well most!)
                            v208-full - (HD, 1.8 GHz, 600 GPU, 720 DDR) Antutu 19,000 with Finless A928 ROM on CX921b TV Box (Rk3188T CPU)
                            Ah, next test round in the evening. :-)
                            JDfense ----> Nexus 7 ~ 2013
                              Hi D33,
                              I have a RK3188T SoC, no need to check the dmesg d33 info for that as it's printed on the chip.
                              Great to hear you've found the solution to the RAM/GPU freq override issue.
                              I'll test it as soon as I get home from work and report back to you.
                              Thanks again for addressing the issue.
                              Regards
                                Originally posted by Pihkal View Post
                                Hi D33,
                                Regards
                                It was the value of the flags I wanted. I needed to know the bit pattern that was trigering the problem. It was sort of good you didn't answer as it made me trace the whole thing (very boring) which allowed me to ge the GPU fix too.
                                Donate to Finless
