Tested with cs968 v2 for the statistics.
JDfense
PS.: Next is neomodes mk809III ROM for the Model T, then I'm back to the JB kernel.
Measy U4B (=Tronsmart T428) used by my kids! Onda v975m - M802 - Bought from Banggood.com Pipo M8HD 3G - RK3188 - don't buy from pipo-store Tronsmart S89 Vega -S802 (sponsored by Geekbuying) CX921b -RK3188T (sponsored by AndroidTV) Cube U30GT2 - RK3188 (part sponsored by Geekbuying) RKM MK902 - RK3188 (sponsored by RKM) |
Donate to Finless |
Donate to Finless |
Donate to Finless |
Donate to Finless |
============================= Rockchip Patchomatic Suite Overclockomatic RK3188 v1.2 by phjanderson ============================= Reading kernel image Done! Searching GPU frequency limit cap Found: 133000000, 600000000 Patching... Searching volt/frequency tables Done! Volt/frequency tables found in the image: == Table 1 at offset 9947136 == MHz mV == Table 2 at offset 9950800 == MHz mV == Table 3 at offset 9950824 == MHz mV == Table 4 at offset 9950864 == MHz mV == Table 5 at offset 9950912 == MHz mV == Table 6 at offset 9952952 == MHz mV == Table 7 at offset 9953008 == MHz mV == Table 8 at offset 9953064 == MHz mV == End of tables == Please identify the CPU, GPU and DDR table. Press ctrl-c to cancel. Which table is the CPU table? (The CPU table is mostly the largest table ranging from 312 to 1608 MHz) 1 Which table is the GPU table? (The GPU table is mostly the second largest table ranging from 133 to 600 MHz) 2 Which table is the DDR table? (The DDR table is mostly quite short, mostly 2 entries, and can be recognized by the labels DDR_FREQ_... at the end of each line) 3 Patching kernels... please wait... ERROR: CPU profile table cpu1608h is larger than the CPU table in the kernel
There are currently 2377 users online. 0 members and 2377 guests.
