It is important to realize that Rockchip designed this code to allow chips with production flaws to be saleable with a performance limitation. In removing this code I haven't fixed the chip and so there is a good chance it will be unstable. I have still left the code to limit voltage on higher leakage chips as this seems dangerous to remove.
I've also tried to fix the CIFS problem with this release.
Please test and feedback. Please test even if you have a different wifi. I will build all versions again but only when I have sufficient feedback that I haven't broken something else and the fixes work.
Version 3:
AP6210
