Kitkat Kernels for All (well most!)
Originally posted by kandilak View PostPlease noderat fix link for AP6120 V3.0. Also, ithought that it was AP6210 and not AP6120
@ noderat: Could you update the broken link with:
http://q.gs/6566554/kernel-ap6210-v3007z
And fix the name from 6120 to 6210.
I'll give you a report later tonight!Last edited by jacobsson; 31 March 2014, 16:40.PIPO-P1@1.6GHz
ROM: RileyROM 1.7CX-919@1.9GHz/798MHz/800MHz
ROM: Finless 4.4.2 BETA
Kernel: D33's AP6210 HD v3.00 +noderat OC
Fan mod: Outside & inside + Antutu: 23694 & Stability test
Originally posted by jacobsson View PostI see, the link that now seem to work is targeting "6210", not 6120 which makes sense!
@noderat: Great job buddy!!! I'll report back to you tonight and see if my CX-919 works.
Is this working for you?
http://q.gs/6566554/kernel-ap6210-v3007zLast edited by jacobsson; 31 March 2014, 16:39.PIPO-P1@1.6GHz
Re: Kitkat Kernels for All (well most!)
Whoops! Okay guys I shouldn't do work at 4am. It's fixed now.
I do have the strangest thing. I opened the case of one of my J22/CX919-II and it showed that I got the RK3188-T. But when I flash this RK3188-T kernel it will only boot up once and after that I keep getting "No Display". When I install the RK3188 normal kernel I get display all the time. Any idea how this may occur?
Thanks a lot.
Hi d33,
Have you had a look at my two DMESGs I sent you yesterday in post#406?CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
1. Both show sound initialising (KK -> asoc: rk-hdmi-i2s-hifi <-> rk29_i2s.1 mapping ok)
2. I can't see ethernet via USB hub in either DMESG!
3. I can see this -> <4>[ 2.086881] enter vmac_probe <6>[ 2.087206] rk29 vmac rk29 vmac.0: ARC VMAC at 0x10204000 irq 51 ee:18:2b:91:f1:4a
In stock.
Okay - I can see it is a special code switch that is associated with RTK8188EU. Will add in and post a 'special' kernel for you to test.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View Post1. DDR overclock makes more impact than CPU/GPU
2. It seems you cannot hold 1.8 stable so don't use.
3. I'd suggest 1.7 CPU 720 DDR 600 GPU
I am facing similar issues as peekeesh but @ 1.6GHz. I am using yours "kernel_AP6210- J22_HD" from kernel_AP6210-J22_v310.
Couple of questions
1. Does this kernel have oc'ed RAM and GPU as well?
2. Is there a way, to change in some file, so I can adjust the OC?Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Couple of questions
2. see post #2Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View Post1. See post #1
2. see post #2PIPO-P1@1.6GHz
Originally posted by jacobsson View PostRegarding #1: the link to noderat's custom OC kernels acts like an endless loop back to #1.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
PIPO-P1@1.6GHz
In stock.
1. Both show sound initialising....
It's something weird because I don't have sound right after the boot but it can appear in 1-5 minutes.
2. I can't see ethernet via USB hub in either DMESG!.....
Do you mean external ethernet to USB adapter I mentioned before? I didn't use it when made both DMESG.
I'll be glad to have this "special" kernel for testingCS918II/16GB(HTC-031-V1.0 board)
There are currently 2466 users online. 2 members and 2464 guests.
