Kitkat Kernels for All (well most!)
Originally posted by petro_ionut View PostThis is my results:
u0_a94@m0:/ $ su
root@m0:/ # fdisk -l
root@m0:/ # fdisk -l /dev/block/sda
Disk /dev/block/sda: 500.0 GB, 500074283008 bytes
255 heads, 63 sectors/track, 60797 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/block/sda1 * 2 1986 15944481 7 HPFS/NTFS
/dev/block/sda2 1987 60798 472393247+ f Win95 Ext'd (LBA)
/dev/block/sda5 1987 60798 472393216 7 HPFS/NTFS
root@m0:/ #
I'll drop him a note.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Interim release (AP6210/AP330 t version only)- Logitech cameras added
- Hub support improved
- Fixed ASIX88179 driver from Yerzu
1.4 GHz CPu & 528 DDR. Use the script in #2 to clock them to your needs.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by Max One View PostHey Dee, i flashed/ tried both of these RK3188 / RK3188T AP6210-J22 Kernels, wi fi and bluetooth is not working. Regards Max One
The labelling and naming of so many devices really confuses everyone.
Does the AP6210 series work?
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by Max One View PostSry for double post but somehow i wasnt able to edit. This rom im using atm kasty-tronsmart_mk908ii_cx919_qx2-442-20131225_rooted4 Am i using a wrong rom, which 1 should i use?
Donate to Finless
j22, cx 919ii, gm 282, dm918, Bluetimes BT919 are all the same. 1 of them is the original ( i think j22) and the other must be the clones of it. i own the Bluetimes BT919. I tested this kernel from lonely2k. After flashing his kernel screen is flashing. Not the known flickering. Its just not working with my device. http://www.freaktab.com/showthread.p...l=1#post126811 This 1 is only wifi working , bluetooth is not working. Cpu frequencies from 1200 to 1400mhz http://www.freaktab.com/showthread.p...l=1#post146692 And no, none of them are working as they should. No wi fi, no bluetooth. RK3188 / RK3188T AP6210 RK3188 / RK3188T AP6210-J22 i tested them all.cx-919ii
Originally posted by d33 View PostThey have been reported working by other "J22" users.
JDfense
j22 / cx 919ii
gpios dumbs by lonely2k http://www.freaktab.com/showthread.p...l=1#post101015 PCB of my Bluetimes BT 919cx-919ii
There are currently 3246 users online. 0 members and 3246 guests.
