Kitkat Kernels for All (well most!)
Originally posted by ma_trix View PostHi d33
Can You build for devices with Mtk chip?
BR
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by roooii View PostWell that's strange because it happens right after I started the device (it's cold then). Problem is solved with the kernel T version. How can I see if I got a T version of the rk3188? Will the T-version run on 1.6ghz or is it locked till 1.4ghz?
Search for "NEOMODE" and you will see the CPU type and eFuse values.
The t kernel can be overclocked using the Perl script in #2
Donate to Finless
Originally posted by scooter2014 View PostAny chance of getting kitkat for the mk902. ???
Is it a tv stick? If so, flash the new t428 rom with the boot.img posted by finless in #72 and then flash the kernel from #1 that matches the radio device in your stick.
Donate to Finless
d33, thanks for your work, i finally find out what model i have and that is MK908II with RK3188T chip()bought this month. I use your kernel_T_AP6210_HD_cpu1704h_gpustock_ddrstock on Finless 2.0 and i have no flickering or restarts(i use additional radiator on chipset) and Antutu score is
With CPU at 1920 won't boot and with 1800 restarts occure.
Originally posted by petro_ionut View Postd33, thanks for your work, i finally find out what model i have and that is MK908II with RK3188T chip()bought this month. I use your kernel_T_AP6210_HD_cpu1704h_gpustock_ddrstock on Finless 2.0 and i have no flickering or restarts(i use additional radiator on chipset) and Antutu score is 17,860.
Thankyou for publishing your success, I'm pleased it works for you. If you wouldnt mind publishing the few DMESG lines that state you CPU model, Leakage level and eFuse it will help us get a feeling for how good/bad a T CPU is 'crippled'. I'll print my own tonight too.
NB. I'd recommend you test the cpu1704h_gpustock_ddr667 RAM version - it will push Antutu to ~19,000 @1080Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
This is DMESG:
<6>[ 0.729853] PMU: registered new PMU device of type 0
<4>[ 0.730014] efuse_version_val: efuse version = 51
<4>[ 0.730057] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 4000
<4>[ 0.730116] efuse_version_val: efuse version = 51
<4>[ 0.730156] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 4000
<6>[ 0.731055] CPU is ROCKCHIP RK3188T
<6>[ 0.731090] NEOMODE the eFuses are (22) = 2b and (23) = 0
<4>[ 0.731468] rk3188 cpufreq version 2.2, suspend freq 816 MHz
I've tried cpu1704h_gpustock_ddr667 but strange thing is that Antutu score is 17400, i have a problem though, my USB hard drive recognised only 1 partition, on Finless 1.5a haven't this problem!
Originally posted by petro_ionut View Postmy USB hard drive recognised only 1 partition, on Finless 1.5a haven't this problem!
[edit: can you send DMESG too)]Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by JDfense View PostSo Mr. D., I have begun to test your kernels on my cs968 ap6210.
First kernel I picked with Finless T428 Kitkat is a good start. It was the kernel_T_AP6210_HD.img.
I have still trouble with booting, the old issue. I need power over otg and after booting I need to add the power connection to get keyboard and mouse over usb. Sounds silly, but you can believe me.
After installation, the rom works more fluid than the last one, I check. It seems very stable with 15736 antutu at 1.42 GHz cpu clock.
This time audio and video work fine, bt too. Only ethernet stays still unconnected.Haven't tested AV video or didital audio out. I have no flickering with this kernel.
You are getting very close.I test another version.
JDfense
Microphone, camera and infra red control does not work. For ethernet I have to check, if could get it with manual adjustment to run.
SD-Card internal and externel is always off after reboot, but I can switch it on.
I found out, that the ROM gets more stable, when I use my 2,3A universal power supply for the otg port and the 3A stock power supply for the power connector, but I must first boot over otg usb and then I have to add the regular power supply at the lockscreen. Finally the usb wireless keyboard/mouse set will be recognized.
It seems not only a question of power supply Ampere. 3A should be enough, but it would not boot complete with the stock power supply.
So fare. Now back to 1600, before I could bake an egg on my TV-box.
JDfenseLast edited by JDfense; 13 March 2014, 06:59.
Originally posted by petro_ionut View PostSecond partition, NTFS, logical. DMESG attached. Thanks.
Looks to me to be ROM related, not kernel?
Using my ipad so apols for any stupid ios spelling 'corrections'Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Performance issues: CX-919
I tested the kernel_AP6210_HD.img on my CX-919:
RK3188 (No 'T' is presented on the label of the CPU)
+ 1080P works great
+ Bluetooth works good
- Wifi limited to 5Mbps
- CPU limitied to 1.6GHz
What did I do wrong?
Any help appreciated!Last edited by jacobsson; 12 March 2014, 21:45.PIPO-P1@1.6GHz
ROM: RileyROM 1.7CX-919@1.9GHz/798MHz/800MHz
ROM: Finless 4.4.2 BETA
Kernel: D33's AP6210 HD v3.00 +noderat OC
Fan mod: Outside & inside + Antutu: 23694 & Stability test
There are currently 3905 users online. 1 members and 3904 guests.
