Kitkat Kernels for All (well most!)
Originally posted by d33 View PostI can look into it.
[edit] Messages come from ROM - I've looked at source and they can be removed but you would need to ask the ROM builder to remove
Originally posted by marko33 View PostHi D33, can you please incorporate the 4.22 fix into the tv stick ap6210 kernel, that fix has solved my no sound and stuck in 720x480 resolution, im currently using the 4.22 tv box kernel on my tv stick, thanks.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by m4f1050 View PostThanks! Could it be in the driver maybe? It's the same messages we were getting in DMESG and somehow you managed to turn those off in DMESG. I have the system.img and can modify it if you tell me where to turn it off I can do it myself.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Donate to Finless
Can you provide a DMESG from stock ROM/kernel?
Just to be sure I've rebuilt the RTL8723au kernel hereCyxtech RK3188 box (cyx_cs918 v2_1) with last sock firmware and SPMC
-> It finally works like a charm !
Originally posted by davy39 View PostMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Thanks,
Here is dmesg from your last kernel_KK_v4.2.4_TVBOX_RTL8723au_SD : http://pastebin.com/7kdPNfz3
Still no wifi & blutooth. I had no way to test ethernet, I will check it later.
Anything else to try ?Cyxtech RK3188 box (cyx_cs918 v2_1) with last sock firmware and SPMC
Originally posted by Pass_00 View Postdo any of these roms work with a rk3066 device such as the mk808b v5 (rtl8723)? losing my mind here with these new versions...
I'm creating a RK3066 TV Stick ROM for RK901/RK903 wifi, might see if I can also get it working for 8188 Realtek wifi. If you PM me your dmesg and GPIO dump I can see if I can make a kernel for your device(RTL8723) to make it work with my ROM, I'm going to release shortly.
Your stick has a different power regulator and this may cause damage
Code:[COLOR=#000000][FONT=Consolas]The device is not act8846[/FONT][/COLOR]
Donate to Finless
Originally posted by mo123 View PostNo, these are RK3188 kernels and only work with RK3188 ROMS.
I'm creating a RK3066 TV Stick ROM for RK901/RK903 wifi, might see if I can also get it working for 8188 Realtek wifi. If you PM me your dmesg and GPIO dump I can see if I can make a kernel for your device(RTL8723) to make it work with my ROM, I'm going to release shortly.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostMO123, if you pass on your .config for the RK3066 I can help too.
cyx_cs918_v_2_1
Ahhh !Thanks for warning !
People with cyx_cs918_v_2_1 do not use d33 kernel, they are dangerous !
This is not a stick but a TV box. See here for related tread in freaktab.
I guess this is the power regulator : pulse h1102NL
Other hardware : rk1000-s, wifi/bluetooth : rtl8723as, ethernet : rtl8201F, HDMI : ite it66121fn
This is the stock dmesg : http://pastebin.com/F6kaCFNv
If you, and/or others (mo123 ?), have time and will to build some kernels for it, I will be glad to be a tester
Apparently, some people are happy to use kernels/roms for Q7 (VECTOR's and lewy20041's) but they doesn't support wifi/blutooth. This board also allows to run K-R42 wasser KK rom, but again without wifi/blutooth.
Edit : would you need me to do a GPIO dump ?Last edited by davy39; 16 August 2014, 13:07.Cyxtech RK3188 box (cyx_cs918 v2_1) with last sock firmware and SPMC
Davey, that is really strange. The stock is also trying to initialise a act8846 and failing.
I'm confused? Perhaps your chip has failed?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 2977 users online. 0 members and 2977 guests.
