Kitkat Kernels for All (well most!)
Originally posted by Benobi View PostOK, so only GPIO dump from stock kernel (working WiFi and Bluetooth), right?
wifi on, bt on - GPIO DUMP 1
wifi off, bt on - GPIO DUMP 2
Wifi on, bt off - GPIO DUMP 3
Wifi off, bt off - GPIO DUMP 4
Then use the analysis stuff from the thread Leolas createdMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by m4f1050 View PostCan someone else with Mediatek help out?.
Thanks to you and D33, it helps us all with these MTK devices!
I did test out the debug_10_oc. The Wifi seemed to work but was getting disconnected every now and then. BT did not work.
Quick question: I need to take the DMESG dump after booting or after some testing?Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by d33 View PostActually if you follow this thread it tells you how to discover the GPIOs by a combination of switching off/on
I just came home.
Installed NeoMode ROM from first post of this thread:
WiFi and bluetooth work great.
Here are all results (thanks m4f1050 for info how to do that):
1. Wifi On , Bluetooth On
gpio.wifi.on.bl.on.txt
2. WiFi Off , Bluetooth On
gpio.wifi.off.bl.on.txt
3. WiFi On , Bluetooth Off
gpio.wifi.on.bt.off.txt
4. WiFi Off , Bluetooth Off
gpio.wifi.off.bl.off.txt
If you need any more help - let me know.
D33 - thanks for your help and support
I hope bluetooth can be fixed and also 720p version can be made
Best Regards,
Benobi
What resolution is reported by Ntutu?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Ugh that looks rubbish!
So you think it is the HDMI res that is wrong - hmmm
I set desktop at 1366 and forced DMT but I remember someone saying HDMI still defaulted to 1920 earlier in this threadMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by Benobi View PostHi,
I just came home.
[ATTACH=CONFIG]7304[/ATTACH]
[ATTACH=CONFIG]7305[/ATTACH]
[ATTACH=CONFIG]7306[/ATTACH]
[ATTACH=CONFIG]7307[/ATTACH]
Best Regards,
BenobiMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I'm afraid that's the end of my holiday. I fly home tomorrow morning (9 hours) so I will be back to my usual (slow) service.
l
No-one came back on the MK7601 / ESP8089 / RTL8723 variants so I guess there isn't a real demandMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostI'm afraid that's the end of my holiday. I fly home tomorrow morning (9 hours) so I will be back to my usual (slow) service.
l
Its really important for me (us)...
I will try to make new files ...
Originally posted by d33 View PostAll four files are identical?
EDIT: Here are the switches
A cleaned DMESG GPIO dump: (you already have this, but this is without the boot dmesg just the GPIO table)
gpio_dmesg_stock.txt
switches:
wifi on, bt on:
gpio_dump_wifi_on_bt_on.txt
wifi off, bt off:
gpip_dump_wifi_off_bt_off.txt
wifi on, bt off:
gpio_dump_wifi_on_bt_off.txt
wifi off, bt on:
gpio_dump_wifi_off_bt_on.txtLast edited by m4f1050; 30 July 2014, 00:53.
Here is a switch dump with newer script (w0 wifi off, w1 wifi on, b0 bluetoot off, b1 bluetooth on)
w1b1:
w1b1.txt
w0b0:
w0b0.txt
w1b0:
w1b0.txt
w0b1:
w0b1.txt
EDIT:
Different switches compared (all 4 with different values side-by-side)
wifi_bt_switches.txt
I hope this last one can help you. I'm sure it has all you need. ;-)Last edited by m4f1050; 30 July 2014, 07:14.
Maybe you could delete the other modes leaving no other choice to the kernel to choose from.
There are currently 6756 users online. 0 members and 6756 guests.
