Kitkat Kernels for All (well most!)
Originally posted by mo123 View PostHi d33
What do you set as wifi device driver support? Voltage 3300? Use the same pins as you.
- You have to set it as 'no wifi' then (I think my setting is correct, but can't test as I don't have such a device)
- MTK Wireless chip configuration - Mediatek MT5931 Config - Power/Reset Both as yes
- Mediatek Combo_MT66xx Wifi Config has to be disabled
- Misc devices - Mtk Wireless Chip configuration - Mediatek Discrete BT Chip MT6622, set to Yes
Please someone test these 2 kernels
Also working on ESP8089, but that works completely different.
Will try to upload those kernels tomorrow for testing.
mt5931_kernel(v2).txt - NCR MTK 1/CS968 - no wifi, no bt
#16 uploaded.
Really hope this gets itMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
bedtimeMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View Postbedtime
No-go no debug16. Good night!
debug16.txt
EDIT: This time I did not see the GPIO BUSY message on the DMESG, but the GPIO DUMP doens't have anything on 278, 279 and 282, is that normal and it's just cosmetics?
Downloads still offlineggrrmmpf
Finally they are back online. Awesome job on these 4.x kernels d33. But however I can't get bluetooth working with 4.2.
Could you help me if I supply you with the DMESG output?
Edit: I looked up some old kernels of yours d33. And with this kernel 4.1 version (kernel_v4.1_TVSTICK_AP6210_HD.img) bluetooth works. Strangely.Last edited by roooii; 04 August 2014, 22:17.
Edit: I looked up some old kernels of yours d33. And with this kernel 4.1 version (kernel_v4.1_TVSTICK_AP6210_HD.img) bluetooth works. Strangely.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by m4f1050 View PostDo we know what the difference between NCR 3.1 and NCR MTK 1/CS968 are? These kernels will not work on "ordinary" ROM's only on those 2 NCR MTK 1 and CS968 ROMS.
[ATTACH]7384[/ATTACH]
Oh how disappointing - thought this would work. :-(
Ahh! I can see it didn't init
will try to sort out the issue tomorrow. At least I know what's wrong now and think we should be close.Last edited by d33; 04 August 2014, 23:37.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I haven't changed the voltagesMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I flashed Neomod 3.1 ROM with d33 kernel (I have 3188t, ap6210, so choosed AP6210_SD kernel) and it doesn't boot. I wait about 20min and it still was on Google TV screen. Also stick was very hot.
Neomod told me that it could be due to D33 kernel.
Can somebody advise what is with my MK809III and what should I do?
Thanks in advance.
Thanks in advance.
If you have a T model it may not be stabile enough for these kernels. Search for a CPU overclock only version 4.2 or higherMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostOh how disappointing - thought this would work. :-(
Originally posted by d33 View PostOdd! 41 & 4.2 are very similar so you shouldn't notice any difference with a stick
I'm still struggling to get my touchscreen monitor to work.
Is it possible for you to apply the modification in post #2 of the following thread to add touch screen support?
My device ID is 2149:2306 (Advanced Silicon Multitouch). I could perhaps even pay you for your time as I really need touch support!Last edited by zero_x12; 05 August 2014, 23:52.RKM MK802 IV Stick (RK3188T 2G/8G)
There are currently 1916 users online. 0 members and 1916 guests.
