Kitkat Kernels for All (well most!)
Technically yes but only Finless has the disassembly skills required and he is unlikely to prioritise itMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
1080i mode
I would like to make a request, can you add 1080i mode to this kernel please http://www.freak-tab.de/d33/kernel_KK_v4.2.5_MT5931.zip
Im using a CS918 clone box and it seems that I get smoothest playback with 1080i. I get green pixels all over my tv screen with 1080p and playback is not as smooth.
Can I add or change it manually in the terminal to 1080i with current kernel? Thanks
Hi d33!
I'm currently trying to get 480i out of the RK1000 (composite tvout) but cant seem to get it, the reason is the screen is from a car navigation with video in and only supports 480i (not p).
Here's my dmesg and gpio's with all combinations possible, also it's a RK3188T with:
LAN: Realtek 8152B
WIFI: Realtek MT5931SA
Bluetooth: Realtek MT6622N
Audio: Rockchip RK1000-S
HDMI: ITE IT66121FN
Power Management: Active 8864QM
Thanks in advancecs918-GPIO-DMESG.zip
LAN: Realtek 8152B
HDMI: ITE IT66121FN
Thanks in advance[ATTACH]7612[/ATTACH]
Originally posted by m4f1050 View PostHi, I have an HDMI to RGB converter for my car video interface and last time I checked it worked on mine. What interface are you using?
Originally posted by elnoodles69 View PostI'm currently using the integrated composite interface on the TV Box, it gets out with the RK1000-S chipset and for what i've read in the pdf for it, it can support progressive to interlaced change, if not i'll have to try with a hdmi to rgb
New kernel very smooth.
Nice to see https://www.facebook.com/freakboxproject .
With the dishonesty going on with some of the sellers out there you can't be sure of getting a decent product or a working one.Mk802IV Neomode 1.9a original rom 720p
Sources public hereMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostPlease provide the values you want me to use
Code:[LIST][*]Kernel-3188-X7/drivers/hid/hid-ids.h[LIST][*]added '#define USB_DEVICE_ID_3M2735 0x053f' to USB_VENDOR_ID_3M section, adding new device-id[/LIST][*]Kernel-3188-X7/drivers/hid/hid-core.c[LIST][*]added ' { HID_USB_DEVICE(USB_VENDOR_ID_3M, USB_DEVICE_ID_3M2735) }, ' to USB_VENDOR_ID_3M section[/LIST][*]Kernel-3188-X7/drivers/hid/hid-multitouch.c[LIST][*]added the following entry in 'mt_devices', list of supported devices by the multitouch driver (in the 3M section)[/LIST][/LIST][COLOR=#333333]{ .driver_data = MT_CLS_3M, HID_USB_DEVICE(USB_VENDOR_ID_3M, USB_DEVICE_ID_3M2735) },[/COLOR][LIST][*]Kernel-3188-X7/drivers/input/touchscreen/usbtouchscreen.c[LIST][*]added ' {USB_DEVICE(0x0596, 0x053f), .driver_info = DEVTYPE_3M}, ' in CONFIG_TOUCHSCREEN_USB_3M section[/LIST][/LIST]
How can I get this information?
When I check this site HERE it shows that my devices is supported by the Generic Multitouch driver, but I don't know how to get the exact parameters you need.
I read through this entire website but don't see any extra information required besides device ID. http://lii-enac.fr/en/architecture/l...h-devices.html
Thanks and I hope we can get it working!!
BTW my devicei as MK802 IV, not sure if I mentioned that.Last edited by zero_x12; 29 August 2014, 17:10.RKM MK802 IV Stick (RK3188T 2G/8G)
There are currently 3976 users online. 0 members and 3976 guests.
