Ok i just opened the case and noticed i have a heatsink over my CPU and its a RK3188T.
Kitkat Kernels for All (well most!)
Am i the only one in here having issues with MK802IV, no matter what kernel or rom i use i keep loosing connection over HDMI. the Device is still on but i have no picture. Only solution is to dissconnect the HDMI kabel and connect it again, works for about 10-30min and than again.
Ok i just opened the case and noticed i have a heatsink over my CPU and its a RK3188T.Last edited by Zeggi; 01 April 2015, 12:15.
Originally posted by mo123
That's your problem, the RK3188T.
Also use a 2 or 3A power adapter, the supplied ones are no good.
I think i fixed the issue for me... i flashed kernel_KK_v4.2.2_AP6210 not 4.2.5. the device is much colder and i havent had any HDMI signal drops for more than 45min.
Who knows maybe the kernel v 4.2.2 works better with RK3188T.
Regarding power adapter im using a Samsung 2A at home and in my car its a 12v energizer dongle with 2 usb ports, 1A and 2.1A.
I have tried a few different power adapters and still the issue is there. I really hope i solved it.
If this doesnt work im planing on buying the RKM V5 or someother RK3288 SOC android stick. (Im using the stick for my carstereo with Appradio unchained) i thought RK3188 would do the job but apparently not.. not sure if Rikomagic is the best option or Amlogic?
Can somebody in this thread recompile the kernel for the RTL8188 wifi chipset with the driver for the CSR8510 A10 bluetooth dongle integrated? I need it for my UGOOS UT1 because it has no built-in bluetooth function. You can find more information in this thread: LINKLast edited by LX+R; 28 April 2015, 04:38.
Hi all ! please say me : what version of kernel "RTL8188 (3.11a)" , i mean 3.0.36 or 3.10.0 (linux version)
P.s. Does anyone else currently porting the kernel 3.10.0 on rk3188 TV boxes ?k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
Originally posted by pes1313 View PostHi all ! please say me : what version of kernel "RTL8188 (3.11a)" , i mean 3.0.36 or 3.10.0 (linux version)
Originally posted by LX+R View PostCan somebody in this thread recompile the kernel for the RTL8188 wifi chipset with the driver for the CSR8510 A10 bluetooth dongle integrated? I need it for my UGOOS UT1 because it has no built-in bluetooth function. You can find more information in this thread: LINKk-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
i use bluetooth on my k-r42 (here on forum availible solution for this) but on my bluetooth speakers sound stutters when i listen internet radio
Could you please send me the permalink for the solution you mentionend? That would be awesome because so far I've not been able to find it by myself.
Originally posted by LX+R View PostCould you please send me the permalink for the solution you mentionend? That would be awesome because so far I've not been able to find it by myself.
P.s i find it in this message http://freaktab.com/forum/tv-player-...251#post290251
this is 100 % worked follow the instructions and all working , BUT ONLY FOR KITKATLast edited by pes1313; 03 May 2015, 23:59.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
I try to find
Thank you, I will try it right now!
Guys,
I have CS968M htc_018, MTK, PCB is version 5, with recent stock ROM from September 2014, the only I can use to change kernel. I cannot use D33 kernel for my device, his version 4.2.5 with MT5931 & MT6022 support, since it will not boot at all, it stuck at boot logo. The question here is about possibility to compile kernel or anything with newer VPU Rockchip RK3188 drivers and modules like libvpu, libOMX, ffmpeg, libbluray, rklibstagefright, libstagefright, libhevc since my video playback is jerky, with a lot of frameskips. I saw there is also new VPU driver on Rockchip site, but I do not know how to use them.
The only working kernel is the one from user SuperCeleron, but I am not good to compile kernel by myself with new modules. The newer VPU drivers are needed for better Kodi or SPMC use, since the old ones messed up video playback so much. I can not use rklibstagefright acceleration, which has the best video performance I have ever seen but everything is in pink color only.
Any help would be appreciated here.
hi d33 i can't find nand flash and sd forAP6210-Alt on my rk3188 j22,thanks
but i chang another rom it can find nand flash and sdLast edited by jihuijun; 20 May 2015, 04:10.
There are currently 2998 users online. 1 members and 2997 guests.
