Thanks very much Darrell.
Kitkat Kernels for All (well most!)
HI Darrell, just wanted to let you know that your kernel have brought great joy to my household. Our previously stock laggy TV stick was a fun gimmick to have, but after the upgrade to KK with D33 kernel it is the central source of entertainment. My wife and I use it everyday, my parents and in-laws love it as well when they visit us, and I assume my baby will grow up using it.
Originally posted by gttommy View PostHI Darrell, just wanted to let you know that your kernel have brought great joy to my household.
Donate to Finless
Hi
I flashed the 4.2.5 AP6210 (kernel_KK_v4.2.5_TVSTICK_AP6210_HD.img) to my cx-919. Almost everything is working well. Except for Wifi... I have the AP6210 module in my cx-919 but it seems to loose connection when i'm using Kodi (XBMC) and try to stream a movie. Running rom: pureX_KitKat_V1_cx921a
Is this a known problem? Is there anything I can do about it?
Kind regards!
Hello D33,
In my DMESG, I have this message "ddrfreq : [disable]ddr freq change to 396Mhz when normal" and the ddrfreq is really locked to 396Mhz (400Mhz) when suspend or normal. However, the log show ddr change freq is working but disabled. How to fix this please ! I'm not use your rom actually but if you help me, please give me an answer. You are more experienced than me in this area. Please help !
Originally posted by ejik View PostFriends, I am looking for a kernel kitkat 4.4.2 WiFi AP6210 (MK808B RK3066)? Only kernek img. to establish through the ROM Tool. Help may have someone else?Your device next firmware is already here!
Er... could somebody please explain what I'm supposed to do with this kernal? I've got a CX-919 II stick that's been a total headache. I've been able to flash the stick with official firmware using RKBatchTool (version 1.7), but the program can't do anything with the kernal. Is there a program I can use to merge the kernal with the firmware I've got? I'll be honest with you, I don't understand any of this. I just want to be able to run games and emulators smoothly, and the stick has been fighting me every step of the way. Thanks in advance for any help you can provide.
Thanks for the effort but MT7601 with MT6622 BT support supposed to work with my EKB311B (RK3118 v2 Box) didn't do the job.
Firstly I flashed the manufactory's (Eny) stock EKB311B_no_logo_root_4.4.2 ROM, KK worked fine, screen looks great but no WiFi no BT.
Then I flashed MM KK 4.4.2 ( http://www.mediafire.com/download/6b...B_MM_KK_ROM.7z ) on it, WiFi and BT worked but got too much ugly flickering, this kernel make the flickering gone but also WiFi and BT.
Switched back to Mo123_custom_v2.img , everything working but JB 4.2. Wish Mo123 will develope KK 4.4.
Originally posted by ArugulaZ View PostEr... could somebody please explain what I'm supposed to do with this kernal? I've got a CX-919 II stick that's been a total headache. I've been able to flash the stick with official firmware using RKBatchTool (version 1.7), but the program can't do anything with the kernal. Is there a program I can use to merge the kernal with the firmware I've got? I'll be honest with you, I don't understand any of this. I just want to be able to run games and emulators smoothly, and the stick has been fighting me every step of the way. Thanks in advance for any help you can provide.
Originally posted by ar_156 View PostThanks for the effort but MT7601 with MT6622 BT support supposed to work with my EKB311B (RK3118 v2 Box) didn't do the job.
None of the KitKat firmwares on Eny's website work.
When I ask them for firmware update, they tell me to buy a new box.
They also make EKB311B, 5 different versions all with different wifi, bt, power settings etc.
You could buy a box from then and the next day again and both boxes will have different hardware but the same name and look the same.
Also some EKB311B was advertised as 2GB RAM, but after flashing other firmware, it only has 1GB RAM. They put firmware tricks in their boxes to trick people about actual RAM.
You can try other KitKat firmware from Nagrace(much better company that help users) here, wifi, bt will also work.
There are currently 2491 users online. 1 members and 2490 guests.
