Kitkat Kernels for All (well most!)
Hi d33, i tried your 4.2.5 kernel (with RTL8723BS support) on my stick (RK3188T), however it does not boot. I also tried to recompile the kernel using your source to change some configuration but still it does not boot. Do you have any idea? My stock kernel unfortunately does not go to full HD. Furthermore i need recompile the kernel to add support for Hanns g 321 Touchscreen support. Any help/hint would be much appreciated! I attached the dmesg from my stock kernel.
Thanks a lot in advanceAttached Files
Originally posted by liha0400 View PostHi d33, i tried your 4.2.5 kernel (with RTL8723BS support) on my stick (RK3188T), however it does not boot.
Donate to Finless
Thanks.. D33.. Your Kernel Solve my Problems
I`ve tried a lots of solutions for my MK 809 III + AP6210 WIFI.
Using a 4.2.x version AP6210-Alt - under test - please report results and Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*, my wi-fi and bluetooth works fine...
I tested a HD and SD version both works for me.
But HD get little laggy...
Now I`m using Neo Mode + AP6210 Alt - SD + Parameter 4GB... Works Really smooth.....
Originally posted by d33 View PostTurn off the RK3188T overrides , your SoC is too unstable to go to 1.6
Originally posted by theos0o View PostHi d33,
Is there any chance you could post some .config's for RK3188 sticks?
Specifically, I'm interested in CX-919 (AP6210, HD).
Could you post the .config you used for the AP6210 kernels you've published?
Thanks!
.config can be extracted from the kernelsMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Hi D33, thanks a lot for your time having a look. I rebuilt again disabling all the 3 overrides (CONFIG_RK3188T_CPU_OVERRIDE, CONFIG_RK3188T_GPU_OVERRIDE, CONFIG_RK3188T_DDR_OVERRIDE = n) and flashed the kernel.img. But nothing happens, not a sign of any HDMI signal. Is this board so picky? So far, I found only 2-3 kernels that would boot (of some gxt_d16_lp board). Any other idea? Thanks again.
Donate to Finless
Thanks for the reply.
I now did that (got it from /proc/config.gz), but my kernel still does not boot, while yours runs fine.
I even reverted to 4.2.5 commit and tried different toolchains.
I do "make ... kernel.img" and flash that img file using RKAndroidTool.
Is that wrong? Should I use "rkcrc" on the Image instead?
Any other ideas?
* (I've built kernels in the past for RK3066 devices with no issues.)
Thanks again.
Donate to Finless
Guest
Hello d33
I have one question..
Can you compile me a kernel for the KitKat Wasser ROM ?
My wifi and Bluetooth are not working in the Rom...wifi/BT are in one Chipset.... All other works well!!!
My Android box is compatible with some boards and have the Same wifi/bt chipset....
K-RK3188-V4.3
K-RK3188-V4.2
K-RK3188-V3.5
And the B351 V2.0
The Wifi/BT Chipset is a RT8723AS
The RT8723AU kernel doesn't worked ...the one thing is i need a kernel with the RT8723AS driver :/.....can you helped me ?
Thx
PROBLEM SOLVED:
I have flashed this one: http://freaktab.com/forum/tv-player-...-android-4-4-2
New rev, version 1.0.4 (latest)
The k-r42 doesn't work but the T-r42 version of kitkat worked...all is worked fine, Bluetooth and wifi ........
I hope i can help other people with this Problem !!!Last edited by Guest; 08 August 2015, 23:44.
Hi d33,
First of all, thank you for your kernels, I use one of them on my mk908ii and am very pleased with the performance.
My question is though regarding another device namely T-R42 with RK3188T CPU and RT8723AS WiFi/BT module.
I couldn't find a kernel from your collection that will work with my device.
Could you please compile a kernel for this device using the latest sources including all your improvements/enhancements ?
Thank you!
Just to be clear, the source code & configuration is now open source and available to anyone to compile. I'm afraid I no longer have the time for this hobby and so any further changes will need to be completed by another active developer on Freaktab.
All sources I've played with are hereMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostJust to be clear, the source code & configuration is now open source and available to anyone to compile. I'm afraid I no longer have the time for this hobby and so any further changes will need to be completed by another active developer on Freaktab.
There are currently 2704 users online. 1 members and 2703 guests.
