(NEW JUST RELEASED) Ultra HiDef Plus4 2MP/5MP 1080P Multi-Media Super ROM AP6210 Wicked Video Resolution Quality (See Photos)
Awesome
Originally posted by Tappy View PostTech1, I want to extend my appreciation for all your work in both the ROM development and help that you give people. I have not flashed my box yet but you have been very helpful, patient, and non condensending in any question or direction you have given me or anyone else I seen on your google community page. Hats off to ya and keep up the good work. Planning to flash this new ROM ASAP.
New 8 Seconds Infomercial In These ROM Builds
NEW 8 Seconds Infomercial Flash Card Now In The "Ultra HiDef Plus4 Multi-Media Super ROMs 2MP/5MP Versions" {Google Android/Nexus TV Forum)
In other words, the CloudnetGO boot screen has been removed from The 2MP/5MP ROMs start screen and replaced with the 8 seconds {Google Android/Nexus TV Forum Flash Card} informercial ....
So Idecided to try and flash the ROM using these directions:
1. get the RK Batch Tool 1.7
2. make sure that "Connect to PC is" disabled (Settings -> USB -> Connect to PC)
3. make sure that "USB debugging" is activated (Settings -> Developer options -> USB debugging)
4. connect the USB-Port next to microSD-Card reader to your PC
5. press the reset button for 3 to 5 sec. to activate debug mode
6. if you haven't installed the ADB (Android Debug Bridge) driver before, select the drivers which are included with the RK Batch Tool package for the new device
7. start the RK Batch Tool and make sure that your device is shown as connected (if your device isn't connected the drivers are not installed correctly)
8. open the custom firmware and start flashing by click on "Restore"
However, when I do step 5. the box does not go into debug mode. The picture goes off and the blue light on the box partially comes on with nothing else on my TV unless I unplug the power and plug in again and then box comes on normally to stock ROM. What am I missing.
AntiVirus Software For Your Android TV Box (FREE$$$)
Bitdefender Antivirus Free is what you want to use on your Android TV box, just to be safe, just in case ...
You can get Bitdefender Antivirus Free HERE https://play.google.com/store/apps/d...nder.antivirus ....
Plus4 Means (Plus4K READY)
Plus4 means Plus4K READY:
"Enhanced Picture Pixel Crystal Clear Video Playback {"Beyond XBMC READY"}
"{HDMI 720P-1080P FUII HD 3D} CR11S ONLY 3D READY}"
"*{Up to 2160P,Resolution 3840*2160} CR11S ONLY 4K READY}"
"Tunko VPN READY, HW Video Decoder READY (No Lag), LibMediaSo READY"
(Taking You To Another Dimension And A Higher Level In Video Resolution Quality)
*please note: the above features of the CR11S are factory built IN, not so with the CS968 to the best of my knowledge ... This doesn't mean you cannot play 3D or 4K video playback with the CS968 (My Point Is Factory Built In Features) ...
KitKat kernels?
Tech1,
I flashed this ROM yesterday on my CS968. This looks very similar to Stock ROM, that I had.
I have some questions:
1. How is the mechanism converting to 1080p via the Terminal Emulator compared to a true kernel supporting 1080p?
2. My Antutu score with this ROM is around 14700+. What is the score that you (or anyone using this ROM) see?
3. Would there be a KitKat version of this ROM available soon? I want to use D33 oc'ed kernels with KK version of this ROM.
Extending my appreciation of putting in this great ROM in place!!Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
That's Why I Don't Believe In AnTuTu Benchmark Scores
Why Is My AnTuTu Benchmark Score So Much Higher, Than the Above Poster (Really No Big Deal) ...? If I Wanted A Higher Benchmark Score To Impress You guys, Believe Me, I Know How To Do That Too ...
That's Why I Don't Believe In AnTuTu Benchmark Scores ....!(lol) I Have No Plans For A KitKat ROM Build Build ... Their Is Nothing Special About A KitKat ROM Build ...! I Was Sent A KitKat ROM Build For The CR11S/CS968 A Long Time Ago ... Maybe Later ...!
The Best 1080p Is In This ROM Build ...! What you want to try, I advise you not to do it, but it's your choice ...!
Originally posted by vodanhdaisu View PostDear
after 3 days of using this firmware, my cr11s started reset automatically randomly. It may reset itself even after 30 mins of using, or 2 hours, or 4 hours
Just to add, incompatible apps can also cause the rebooting cycle ... Their has been a huge amount of downloads for the 2MP and 5MP ROM builds, it's still early, we see if anymore rebooting reports come to our attention for help ...Last edited by Tech1; 02 April 2014, 16:24.
nba game time app
Hi tech1,
i have trouble with nba game time time app with CR11S.
I installed 5MP version rom and tried to install before the offcial nba game time app but i verified that the official app is non compatible with the CR11S.
After that, i installed the alternative nba game time app (nbadigital) but as soon ad i try to open it, immediatly it crashes. Im going crazy, i dont know why is not possible to open it properly and what can be the trouble with it!
Please if have possibility, try to help me because im very frustrated: one of the main reason that i buyed an android tv (and i liked very much this CR11S with tour rom) was for the nba game time app!
Thanks in advance.
Rob
There are currently 4834 users online. 0 members and 4834 guests.
