Sent from my Galaxy Nexus using Tapatalk
(NEW JUST RELEASED) Ultra HiDef Plus4 2MP/5MP 1080P Multi-Media Super ROM AP6210 Wicked Video Resolution Quality (See Photos)
Originally posted by Tech1 View PostStill working like a charm ...
EDIT: Fixed, something must corrupted. I boot into recovery and the Android spinning for awhile, the the device reboot by itself, when it's up, I opened the showbox app and voila!..working again back to business!!
EDIT1: Spoke too soon, it was working until I closed the app and then reopen it again, same thing happened, open then immediately closed... I wonder if it has anything to do with ad blocker...will report back if I found the issue.
EDIT2: Yes issue resolved, my adblocker is the cupit. Disabled adblocker, reboot and working normal again. To be sure I reboot couple times and Showbox stills working great! case closed.Last edited by buhohitr; 14 April 2014, 02:53.
Confused!!!
Hi guys! Just signed up. Got lots of questions. I am currently testing a CS968, and I woud like to give this ROM a try. What I'd like to know, does this ROM already have the LibMedia.so hack implemented? If I install this Rom along with JustXBMC or BeyondXBMC, will it allow me to HDMI pass through DTS and DD?
Do I have to install MX Player for it to work?
After I have everything installed, what settings do I adjust in the ROM, and in XBMC?
I've done a lot of reading, but it's kind of confusing!
What I'm trying to do is stream my movies from a HDD plugged into my router.
Thank-You!
cannot save audio setting, always back to default RK1000
TECH1,
I just get optic cable then I switch audio setting to SPDIF passthrough
However every time device being power off (AC plugout),
audio setting goes back to default RK1000
Anyway to force default audio setting as SPDIF passthrough?
Originally posted by TomThumb View PostHi guys! Just signed up. Got lots of questions. I am currently testing a CS968, and I woud like to give this ROM a try. What I'd like to know, does this ROM already have the LibMedia.so hack implemented? If I install this Rom along with JustXBMC or BeyondXBMC, will it allow me to HDMI pass through DTS and DD?
Thank-You!
Originally posted by Tech1 View PostDon't feel bad that you cannot save your audio Settings, that's one of defects of our 4.2 ROM builds ... This has been fixed in the new 4.4 Kitkat ROM builds ...
Not sure either whether network video streaming fast enough compare to your 4.2 ROM
I do have Kitkat ROM in my Asus Transformer and network video streaming is slower than your 4.2 ROM
Your 4.2 ROM is good enough, it's just that audio setting annoying
So no chance to hack default audio setting?
Beyond XBMC V3.4 Rules {Hands Down With The Option To Use The MXPlayer For Local Video, Movies Playback}
NEW Channels Addons zip Download Location Below, Please Read The Simple Easy Instructions First ...
If You desire ALL the top addon channels via the Beyond XBMC v3.4, then you will need the NEW XBMC7.9 Updated Channels.zip files ..
You will need to unzip the "XBMC7.9 Updated Channels.zip" on your PC and install "XBMC7.9 Updated Channels folder" to your Android TV box internal SD Card "Download Folder" ...
There you can easy access each addon channel zip files to install them by just tap/click on each addon channel zip file, one at a time to install the channels addon zip file to your Beyond XBMC V3.4 ..
*You want to install the "repository Superrepo.org.all addon zip file" FIRST, located in the "XBMC7.9 Updated Channels folder" immediately after the Beyond XBMC v3.4 open during the first installation by going to SYSTEM> Addonbrower (tab below)> "Install from zip file"> External storage> Download (folder)...
There in the Download folder you will see the "XBMC7.9 Updated Channels folder", tap/click on it and install each addon channel zip one at a time ... Each time you will auto go back to "Install from zip file", just repeat the install process for each addon channel zip file ..
You can get the "XBMC7.9 Updated Channels.zip" from HERE IN THE TOP POST https://plus.google.com/communities/...artnerid=gplp0 ...
You can get the latest Beyond XBMC v3.4 HERE
http://www.freaktab.com/showthread.php?10139-Beyond-XBMC-%28Beta-3%29 ...
Originally posted by nictus34 View PostThanks Tech1 for a great ROM . I have tried 4.4 Kitkat cloudnetgo and Ultra Hidef 4.2.2 ROM.
Ultra Hidef 4.2.2 ROM Picture quality is excellent and 1080p HD playback is smooth.
My android box is CR11S model with version 4 motherboard.
Originally posted by chenrp View Post1. will this ROM works with V4 device? (AP6210 + RK3188T)?
2. will there be an update for this ROM (to work in 4.4 kitkat)?
thanks
The 4.4 KitKat versions of these ROM builds can be found HERE http://www.freaktab.com/showthread.p...per-ROM-AP6210 ... Custom 4.4 KitKat ROMs {Spoofed As A Nexus 7} ...!
Originally posted by edwardckc View PostHi Tech,
I have flashed this super rom and install Beyond XMBC 3.4
when I play 1080P MKV with DTS or DD (over 10GB per file), not so smooth, anythings I need to do? need change the libmedia.so? or copy advancesetting.html to XBMC folder?
Many thanks
https://plus.google.com/communities/...artnerid=gplp0 and read about how to set up the MXPlayer correctly to help with tuff video files playback, it's a new series just released as promised ...
There are currently 2236 users online. 1 members and 2235 guests.
