(NEW JUST RELEASED) Ultra HiDef Plus4 2MP/5MP 1080P Multi-Media Super ROM AP6210 Wicked Video Resolution Quality (See Photos)
Originally posted by buhohitr View PostCan you give me the direct link to download the latest 4.4 kitkat rom that would work with beyond xbmc 3.4?? I went to your Google page but kind of confuse...since you have about 3 different ones. Thanks.
Originally posted by Tech1 View PostGo back here https://plus.google.com/communities/...artnerid=gplp0 and scroll down to post number 0707, expand it, the 2MP and 5PM fast download links are there ..
Thank you!
XBMZ Prototype Build, Just About ALL Add-Ons Installs And Works
XBMCZ Tech1 Wizard
Here is new and better prototype XBMCZ with better text resolution http://www.mediafire.com/download/dg...ch1-Wizard.apk ...
1080p Videos/Movies Smooth Playback Instructions:
1.\ Go To System> Settings> Video> Settings level, Change to "Expert", next go above to Acceleration and uncheck -Allow hardware acceleration (MediaCodec) ...
This should give a much smoother 1080p video/movies playback experience ...
XBMC most popular add-ons {Channels}, you can manually install can be found here http://www.mediafire.com/download/5o...s_Zip_Files.7z
GITELLA Picture Pixel Crystal Clear {Live USA TV Streaming Services} Install To Your Android TV Quad Core 4.4 KitKat Box For Live TV {Also Install To Your Android SmartPhones/Tablets For ChromeCast Casting Functions HOT! HOT! HOT FREE$$$
Download The Gitella Live TV Streaming Services App HERE HOT! HOT! HOT!
https://plus.google.com/communities/...artnerid=gplp0 ...Last edited by Tech1; 25 May 2014, 16:41.
XBMCZ Tech1 Wizard
NEW UPDATED XBMCZ Tech1 Wizard
XBMCZ NEW UPDATED {XBMCZ Tech1 Wizard Gotham 13 Build Prototype} I Decompile/Recompile The XBMCZ.Apk, Installed Files From Other XBMC Builds To Enhance
Just About ALL Add-Ons Installation And Music/Video/Movies Playback ... All Add-Ons I tested, Installed, Played very well ... From Time You might get odd behavior, But Nothing Serious ...
Feel free To give it a test RUN ... I believe This XBMCZ Prototype Can Be Perfected ...
XBMCZ Tech1 Wizard
Here is a new and better prototype XBMCZ with better text resolution http://www.mediafire.com/download/dg...ch1-Wizard.apk ...
XBMC most popular add-ons {Channels}, you can manually install can be found here http://www.mediafire.com/download/5o...s_Zip_Files.7zLast edited by Tech1; 25 May 2014, 16:40.
A awesome guide for setting up your Beyond XBMC or Gotham XBMC by Convic Tech https://www.youtube.com/watch?list=U...&v=0XrH1JVQb7w
I like this set up because you can have AC3 DTS with either your Beyond XBMC or Gotham XBMC ... It makes the MXPlayer the default player for local media files playback {Custom Codecs Must Be Installed For AC3/DTS} ... It makes the Wondershare player the default XBMC DVD player {Use The Wondershare Player In The Package below, If You Are Using A CR11S/CS968} ...
Here is the apps set up package including the playercorefactory.xml file for the CR11S/CS968, just install all the apps in the package http://www.mediafire.com/download/cd...13-14_Files.7z ...
NEW Official Custom CR11S/CS968 4.4 KitKat ROM Builds 20140526 Released
9999: NEW CR11S/CS968 AP6210 OFFICIAL CUSTOM 4.4 KITKAT Multi-Media Super ROM5
{JUST RELEASED 20140526. ENHANCED VIDEO RESOLUTION QUALITY, BUILT IN UPDATED NETFLIX, LIVE TV, AND BEYOND XBMC {WORKS WITH THE CONVIC TECH XBMC PACKAGE}
Get This ultimate Super ROM HERE
{Scroll Down to post number 9999, expand the post, there you will find the fast Download links}
Originally posted by Tech1 View PostYou want the new one just released ...
There are currently 2180 users online. 0 members and 2180 guests.
