New hardware for MK809III / CX-919II / RK3188-T and MT6622N with ESP8089
    Finally Android 4.4.2 KitKat ROM
    Originally posted by kristoma View Post
    http://pan.baidu.com/s/1jG5K5ym
    There is a cyxtech_rk31_dongle_8089 6622 _4.4_140402.rar file
    Kitkat rom for our stick ?
    other baidu link
    http://pan.baidu.com/share/home?uk=5...ategory/type=0
    I just tested this ROM:
    It's Android 4.4.2 KitKat ROM.
    And it works GREAT. Wifi WORKS. Videos play SMOOTHLY.
    I didn't try BT.
    Here are some screenshots:
      How can I back my full rom up without having Cwm recovery installed? Not compatible for my device.
        I didn't try BT.
        have you tried 1080p ?
          I didn't try BT.
          And it seem's to be root
          edit : it's not
            you can look at this :
              Yes, I did, and it's not perfect. There is some flickering, like it disconnects for a milisecond from the HDMI... I tried 50Hz and 60Hz, it's the same. But on 720p works very smooth.
                rom 140509 is the first one for me without flickering, perfectly clean and smooth.
                  my dosn't seem to be rooted ;/ Superuser fails
                    Is there any way of getting the screen properties of rom 4.2(drivers) and getting it to 4.4 version? so i can finally have 1080p?
                      I basically have the same hardware as this stick (ESP8089 and MT662N) in a CS918/T-R42 box. Since I have a built in ethernet port and of course more ports than a stick, would I have a problem with anything? Like any settings missing or anything?
                        alternative download link
                        Kindly if someone can upload the file to some where else than China. I tried to download the file few times but it stops in the middle as the connection is too slow. Thanks in advance!
                        http://pan.baidu.com/s/1jG5K5ym There is a cyxtech_rk31_dongle_8089 6622 _4.4_140402.rar file Kitkat rom for our stick ? other baidu link http://pan.baidu.com/share/home?uk=5...ategory/type=0
                          cyxtech_rk31_dongle_8089 6622 _4.4_140402.rar MIRROR
                          MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
                          just tried on my CYX_809III_RK3188. PERFECT!! WiFi & BT recognised and working!! but it only support 720p (on mine)
                          It's a 4.4.02 Android not rooted. i have used this tool to overwrite the fw: https://mega.co.nz/#!oNZUxZAC!hmanV2...WCGR_HEJOLrTAs (RK BatchTool)
                          To use that FW, just use a clip to enable the RK USB Loader and then just "Update" it
                          To root this FW you can use RootGenius (remember to launch it as Admin)
                          [EDIT]
                          i've changed the TV and 1080p works. PERFECT ROM!!
                            Originally posted by Deroad View Post
                            [EDIT]
                            No flickering screen issues at all are there?
                              nope. i just noticed, after rooting, it sometime crash after installing an app
                                As long as the apps aren't affected after a reboot, that shouldn't be a problem
