New hardware for MK809III / CX-919II / RK3188-T and MT6622N with ESP8089
</form>
Originally posted by Damo View Post
I have included a driver in the latest kernel build above, test it with Sam's ROM and post a DMESGMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
"Using RKAndroidTool to flash image by partitions" http://wiki.radxa.com/Rock/flash_the_image
First of all, thanks for the great work everybodyIt looks like you've got a working KK Rom now and i want to install it on my stick this weekend to see if it works. But i'm a bit confused now: which version is working best now? I don't have a LAN-adapter (yet
) so i only want to use WiFi and have the best possible performance in SPMC/XBMC. Is 1080p now possible? Which rom should download? Which kernel?
*update: can i flash from Win8.1 or should i use Win7?
*update 2: how do i get it to flash? I'm seeing the device in the RKBatchTool but it's pink. When i load the FW and press 'switch' the device goes away but doesn't come back in Flasmode (green).. How to flash it now?
This is an update to my ROM
What is new
1: fixed the issue where the WiFi/bluetooth would not switch on properly on the first boot
2: updated the kernel to the latest from D33
3: changed the flashing tool/img format so the user can have control over what to flash
4: included are 3 kernels they are located in the "Extra Kernels" folder
please insure if upgrading from Jelly bean that you flash the loader
Please switch the kernel in RKAndroidTool to "kernel_D33_HD" it is located in the "Extra Kernels" folder
link to My ROM
Originally posted by sam321 View PostThis is an update to my ROM
What is new
link to My ROM
https://www.dropbox.com/s/3r4sftyzon...m_Rom.zip?dl=0
Dont quite no what happened but followed instructions flashing rom, not using the extra kernals, with loader selected, screens during flashing and after.
Same screen after resetting, maybe just a bad flash, see images below.
Flashed the kernel_D33_HD kernel from the extra kernels folder and perfect
Wifi now connecting and stays on after switching stick on and off.
Bluetooth is also working.
Video files playing smoothly
No Hdmi Flickering, screen solid
So fingers crossed I think I now have the perfect rom for this device, so once again a big thankyou to Sam123 for his patience and commitment in getting users a great working rom, and D33 for his great work on the kernel.
Il keep testing...
I dont know if it is a coincidence but replaced the power supply from the cheap crappy one supplied also after flashing rom, as I was experiencing anomoly previously with wifi etc, who knows.
</form>
Originally posted by d33 View Postfile is password protected
[edit] I found some drivers elsewhwere
I hope this is the file you need for the lan adaptor I have
jp1081b 9700
It is 9700_android.tar.gz
Thank youPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
jp1081b 9700
Thank you
I have already put a QF9700 driver in my kernel. Is it not working? Can you provide DMESG?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Ok I will sorry manPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by jiepiewie View PostAnybody any tips how to flash my cyx809_III? I still can't get it in Flash-modus aka green icon...
Originally posted by sam321 View Postum strange as it is D33 SD kernel that is used by default
I will reflash again Sam just as it it set up in the flash tool, to retestPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by sam321 View Posthave you installed the Rockchip drivers, try putting it in flash mode by using the Fn button/reset button it is on the side of your stick, there might not be a button there but there will be a small hole, keep the button pressed down while plugging it in to your PCI've got a driverpackage installed calle 'Fuzhou Rockchip (Rockusb) Rockusb Device (08/05/2013 3.70.000)' and have tried turning it on whilst holding the reset button for almost a minute. No good: the rockchiptool didn't even find it... Are perhaps the drivers wrong? I'm using W8.1 could that be a problem?
There are currently 4740 users online. 1 members and 4739 guests.
