New hardware for MK809III / CX-919II / RK3188-T and MT6622N with ESP8089
    jiepiewie. there are problems with win8.1 try following the instructions here it might help http://www.cnx-software.com/2013/11/...-windows-xp78/
      That's the driver/tutorial i followed to install the drivers I'm seeing the following in the logs when using the rkandroidtool:
      15:22:31 649 Load Setting ok
      15:22:31 704 Sam321 - RKAndroidTool v1.3.7.0 Start Run
      15:22:31 706 Scan thread:6380
      15:22:31 708 Infothread=6048)IoControlProc-->DeviceIoControl In
      15:22:31 710 Infothread=6048)IoControlProc-->DeviceIoControl Out,ret=1,err=183
      15:22:31 712 Infothread=9580)IoControlProc-->DeviceIoControl In
      15:22:31 713 Infothread=9580)IoControlProc-->DeviceIoControl Out,ret=1,err=183
      15:22:31 718 Infothread=5836)IoControlProc-->DeviceIoControl In
      15:22:31 720 Infothread=5836)IoControlProc-->DeviceIoControl Out,ret=1,err=183
      15:22:31 725 Infothread=9920)IoControlProc-->DeviceIoControl In
      15:22:31 726 Infothread=9920)IoControlProc-->DeviceIoControl Out,ret=1,err=183
      15:22:31 728 Infothread=1012)IoControlProc-->DeviceIoControl In
      15:22:31 729 ProcessID:9804,ThreadID:6552,RefCount:0
      15:22:31 730 ProcessID:9804,ThreadID:6380,RefCount:0
      15:22:31 732 ProcessID:9804,ThreadID:6048,RefCount:0
      15:22:31 733 Infothread=1012)IoControlProc-->DeviceIoControl Out,ret=1,err=183
      15:22:31 760 Infothread=1504)IoControlProc-->DeviceIoControl In
      15:22:31 763 Infothread=1504)IoControlProc-->DeviceIoControl Out,ret=1,err=183
      15:22:31 769 Infothread=6568)IoControlProc-->DeviceIoControl In
      15:22:31 770 Infothread=6568)IoControlProc-->DeviceIoControl Out,ret=1,err=183
      And the device itself is available as an USB-disk and it's accessible. Just not flashable...
        jiepiewie. I am out of ideas, what happens when you press the "Reboot2Flash" button in RKAndroidTool
          um strange as it is D33 SD kernel that is used by default
          yes reflashed sam and got the same screens, when it boots its got four screens in the centre..
          UPDATE
          From the extra kernels folder
          Flashed kernal:
          kernel_Stock_no_OC :Get the corrupted screen
          kernel_D33_SD :Get the corrupted screen
          kernel_D33_HD:Works ok, no corrupted screen.
          After flashing last night your rom with kernel _D33_HD the wifi connected, authenticated and stays connected for 3 reboots.
          But this morning the problematic Wifi again not connecting, even though shows full strenth in the settings screen. When I click to forget my home wifi and try to connect it again the authentication screen doesnt come up. WTF
          Cant way it up
          UPDATE: trying a different wirless modem
          </form>
            Weird
            I will edit my release post above to tell people to switch to the D33_hd kernel, there is not much more that I can do for now
              I get a popup-window stating "Device can not do Flash Mode,because of no drive."
                Originally posted by d33 View Post
                DAmo,
                I have already put a QF9700 driver in my kernel. Is it not working? Can you provide DMESG?
                Here is the Dmesg you asked for D33
                Was a bit long to enter it into forum
                Btw would this file give an indication why the WiFi connects using the Hd version on your kernel with Sams new rom, than seems to stop working
                Thank You
                If it helps this is the Dmesg is from Sams Jellybean rom, and the wifi works properly on this
                </form>
                  Thank you Sam123
                  I have switched my Wireless router to a different one. Has maintained Wifi up to now.
                  Maybe was just that
                  </form>
                    Are you sure you have got USB debugging on. Other than that I have run out of ideas
                      I'll try again on another PC with W7. Perhaps that does the trick. I'll also look at the USB-debugging. I'm almost sure it's on but i'll check it anyway.
                        OK, I have been trying to work this out all day and I found the following out
                        1: QF9700 lan adapter does now work, how do I know, simple, I rang around all my friends and eventually got one, I can provide a DMESG for proof
                        2: D33 kernel does not overclock the RAM, how do I know, simple, I built my own kernel and found out the RAM needs init at the start, so he is init @300mhz and that is where it stays with my kernel set @667mhz it is much faster proven by Antutu
                        and as for the WiFi I just cannot get it to fail, if I cannot reproduce the problem then I cannot fix it, Damo are you sure you have not got a lot of people around you on the same WiFi channel, I had the same problem a while ago until I trained my neighbours lol
                          I have mine set to channel 11, so its away from the neighbours. Its just weird that it happens with Kitkat roms. The jellybean rom you made , with fixed video stutter just works with the WiFi, every time the stick is turned on and off.
                          Even the stock Kit Kat rom from China the WiFi don't work.
                          Is it a faulty WiFi chip ? Seems strange how it would work on Jelly bean. Think I made the wrong choice when I was looking on ****, didn't realise there where so many variations or clones of the Mk809iii, who the heck makes the original one.
                          </form>
                            I know what you mean about clones of the clones, I stopped worrying about that a year or so ago and just gave up I do not know how D33 does it, I would have given up a long time ago, which I did lol. unfortunately I don't know what is happening with your WiFi it should work , although I will keep testing
                              I have my lan adaptor plugged into a homeplug near the stick, but I have had no success getting that to work. Has yours got a micro usb connector or is it full size usb.
                              </form>
                                I think the postman sat on my stick for an hour before he delivered it lol squashed my WiFi chip. I really appreciate the effort you have put in to this 😊
                                </form>
