New hardware for MK809III / CX-919II / RK3188-T and MT6622N with ESP8089
    The wifi firmare is loaded from binaries stored in /system/lib/modules. I suggest you compare the vesrions of these in the stock ROM with the custom ROM.
    Donate to Finless
      Many thanks to all your hard work.
      I have try it, maybe i am doing wrong, but it do not success with this kernel. (Bootloop or reboot)
      I tried with Neomode-Custom-Rom-MK809III-Version-3-1-Android-4-4-2-*Update* or cyxtech_rk31_dongle_8089 6622 _4.4_140402
      Do you have an example of ROM with which this kernel work?
      What tools have you flashed ?
      The parameter file must be modified ?
      @D33 : About ethernet driver, i got an adaptator too. Can you please verify if this driver can be integrated :
      ch9200 / ch9100
      (i have the driver on a cd at home)
        If it doesn't boot chances are that your SOC has an unstable PLL
        Donate to Finless
          USB ethernet drivers
          # USB Network Adapters
          # CONFIG_USB_CATC is not set
          # CONFIG_USB_KAWETH is not set
          # CONFIG_USB_PEGASUS is not set
          # CONFIG_USB_RTL8150 is not set
          # CONFIG_USB_RTL8152 is not set
          CONFIG_USB_USBNET=y
          CONFIG_USB_NET_AX88179=y
          CONFIG_USB_NET_AX8817X=y
          CONFIG_USB_NET_CDCETHER=y
          # CONFIG_USB_NET_CDC_EEM is not set
          CONFIG_USB_NET_CDC_NCM=y
          # CONFIG_USB_NET_DM9601 is not set
          CONFIG_USB_NET_DM9620=y
          CONFIG_USB_NET_SR9700=y
          CONFIG_USB_NET_SR9800=y
          # CONFIG_USB_NET_SMSC75XX is not set
          # CONFIG_USB_NET_SMSC95XX is not set
          # CONFIG_USB_NET_GL620A is not set
          CONFIG_USB_NET_NET1080=y
          # CONFIG_USB_NET_PLUSB is not set
          # CONFIG_USB_NET_MCS7830 is not set
          # CONFIG_USB_NET_RNDIS_HOST is not set
          CONFIG_USB_NET_CDC_SUBSET=y
          # CONFIG_USB_ALI_M5632 is not set
          # CONFIG_USB_AN2720 is not set
          CONFIG_USB_BELKIN=y
          CONFIG_USB_ARMLINUX=y
          # CONFIG_USB_EPSON2888 is not set
          # CONFIG_USB_KC2190 is not set
          CONFIG_USB_NET_ZAURUS=y
          # CONFIG_USB_NET_CX82310_ETH is not set
          # CONFIG_USB_NET_KALMIA is not set
          # CONFIG_USB_HSO is not set
          # CONFIG_USB_NET_INT51X1 is not set
          # CONFIG_USB_CDC_PHONET is not set
          # CONFIG_USB_IPHETH is not set
          # CONFIG_USB_SIERRA_NET is not set
          # CONFIG_USB_VL600 is not set
          # CONFIG_WAN is not set
          Donate to Finless
            Originally posted by d33 View Post
            I include a number of USB ethernet drivers in the kernel. Let me know your chipset and I'll add yours too.
            My model printed in board is
            Cyx_809iii_rk3188 v2.1 20140408
            Esp8089 WiFi
            Mt6622N
            </form>
              Esp8089 WiFi
              Mt6622N
              The chipset of the USB ethernet! See list of possibilities above
              Donate to Finless
                Sorry d33, how would I find that information my technical knowledge is rather unsuperior to yours.
                Thanks man
                </form>
                  Thanks man
                  Plug it in to a laptop and see what driver Windows uses? Look in the packaging for a driver disk? Search internet on the part number?
                  Donate to Finless
                    Thanks man. I will have a look tonight when I finish work.
                    Thanks again
                    </form>
                      @D33 : My USB / Ethernet adaptator is CH9200, the drivers can be find here : http://gdurl.com/ZRmL/download
                      it does not appear to be listed above
                        Thanks again
                        There is a really cheap one off **** you can get that is very common, it's a see through blue one from china for around £2 which works on near any rk device known to man.
                        It'll max out at 1meg a second though, absolutely fine for streaming/HD movies from LAN (not insanely high bitrate ones mind)
                        Also as mentioned previously, these heat up like no mans buisness for some reason with an unlocked kernel. It's needed to get the best movie performance as the GPU mhz is increased around 50%.
                        I did try replacing libs from stock to custom without much success, I'm sure someone more familiar with android than me may be able to shed some light on it.
                        Thanks for the kernel d33, it's very much appreciated.
                        Currently Using:
                        2 x Nvidia Shield TV | MiniMX III
                        Retired Devices:
                        MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
                          We're the esp8089 libs different (stock vs NEOMODE)?
                          Donate to Finless
                            Ok found some information for my lan adaptor.
                            Profile
                            JP1081B USB to RJ45 Ethernet 10/100 Mbps Lan Network Card Adapter - Black
                            Quick Details
                            Products Status:
                            Stock
                            Application:
                            PC & Laptop & Tablet
                            Type:
                            Wired
                            Kind:
                            External
                            Transmission Rate:
                            10/100Mbps
                            Interface Type:
                            USB & Micro USB & Mini USB
                            Certification:
                            CE & ROHS & FCC
                            Brand Name:
                            JPHX
                            Model Number:
                            JP1081B
                            Place of Origin:
                            Guangdong China (Mainland)
                            Application:
                            Laptop & Desktop & PC
                            product size:
                            58*22*17mm
                            Product NW:
                            20.6g
                            Unit Packing size:
                            165*115*20mm
                            Product GW:
                            41.4g
                            Colors:
                            White & Black
                            Power:
                            1W
                            Connection Speed:
                            10M/100Mbps
                            Operating temperature:
                            -25 °C ~ +70 °C
                            Storage temperature:
                            180MA/5V
                            Tec. Specifications:
                            1.Chip
                            RD9700
                            2.Connection Speed
                            10M/100Mbps
                            3.Operating voltage
                            4.2-5.5V
                            4.Power
                            1W.
                            5.Operating Frequency
                            48MHz/125MHz
                            6.Operating temperature
                            -25 °C ~ +70 °C
                            7.Storage temperature
                            -40 ~ 85 °C
                            8.Relative Humidity
                            10% ~ 80% (non-condensing)
                            9.Operating Current
                            180MA/5V
                            </form>
                              Think this adaptor had been discussed here.
                              </form>
                                "Sorry, you can't view or download this file at this time."
                                Donate to Finless
