New hardware for MK809III / CX-919II / RK3188-T and MT6622N with ESP8089
Originally posted by Damo View Post
[edit] I found some drivers elsewhwereLast edited by d33; 26 September 2014, 21:23.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Sorry Il find another site to get driversPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Damo View PostThank you 😊 Sam!!
Flashed this morning before work, followed instructions , although WiFi showed up in the list it would not connect. Did factory reset, restarted a few times and connected to WiFi 😊 .
Bluetooth works.
Will play more tonight, but a big thankyou to Sam123 and D33
Seems the WiFi does not keep connection after turning my stick back on tonight. Turned WiFi off than it said not in range.
Did another factory reset , entered password, but does not authenticate.
Seems like the same problem with all the other kit Kat roms I've tried.Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Damo View PostSeems the WiFi does not keep connection after turning my stick back on tonight. Turned WiFi off than it said not in range.
Originally posted by Johny View PostMay I ask you to compile also drivers from post #48 on site http://www.freaktab.com/showthread.p...l=1#post191137
ThanksMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I will try that thank you SamPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by sam321 View PostAnd as a side note your lan adapter should work now on this ROM. Have you tried it ?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by sam321 View PostI fixed the original problem with my ROM, I am going to upload a new one. just so you know every time you do a factory reset it causes the old problem to appear, as a temporary fix until I upload my new ROM try this, do a factory reset, wait until it loads into android OS and just remove all power, do not try to shut it down properly. And as a side note your lan adapter should work now on this ROM. Have you tried it ?
Tried that still same problem.
The lan adaptor is plugged into the micro usb port on the stick, I presume this will work from that port.
Turned on ethernet in settings, again I presume it auto configures as there are no settings, only to set a static ip address.
Doesn't seem to work if that's the casePlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Right - sorted
HD & SD versions with CH2x00, QF9700 & ASIX88179 USB ethernet drivers
Download
Pushed to GitMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostWhere did you get qf9700 drivers from? The ones I downloaded have problems with usbnet and net_device structs
Originally posted by sam321 View PostNo you misunderstand, the original ROM would not work with any lan adapter. The ROM I made will work with any lan adapter it as long as the drivers are present in the kernel or are loaded up manually, sorry for the confusionMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by sam321 View PostYES 100% the ROM does work with lan adapters, I tested everyone I own and they all work which is why I went to all this trouble to create this ROMMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 4741 users online. 1 members and 4740 guests.
