Official News from here - the 3rd red bold text contains link to RK Image tool
download link here 20140424 the link is down
firedrive link here 20140419
New firmware 20140424 from this thread by andylcm and is not rooted
Cheers,
here's some noted changes (htc_t018_public_4.4.2_mtk_20140419),
- it's stock rom so not rooted,
- kernel is 720p
- beyond xbmc is pre-installed
- some chinese 3rd apps
- free internal memory is 1GB now, (4.2.2 is 1,9GB)
- nand flash (internal sdcard) 5,3 GB now, (in 4.2.2 is 3.9GB)
- HDMI output is by default set to 1080p 60Hz
- "SMART BOX" boot animation
- Device known as CS968M,
- It wake's up upon tv-on via hdmi, (no need to worry to turn-off the box) just notice it.
here's some noted changes (htc_t018_public_4.4.2_mtk_20140424),
- kernel is 720p
- free internal memory is 1,9 GB now, (same as 4.2.2 is 1,9GB)
- nand flash (internal sdcard) 3,9 GB now, (same as 4.2.2 is 3.9GB)
- HDMI output is by default set to 720p 60Hz
- Auto detect av output (hdmi or av 3.5mm) hence the display menu will give you different submenu except scale
* to root it you need kingoapp please follow tech1 and its people who help write the procedures in his thread here
or
* using sjroot here, info from jiasheng
- to install driver use RK_Driver Asistant - tutorial from minix forum admin here
Tips : After each flashed please do a "Factory Reset", you can access "Factory Reset" in Setting -> Backup & Reset
