CS968 MTK KITKAT ROM 4.4 - Finally
Downloaded new firmware
Originally posted by pejochto View PostDoes anyone managed to download this new ROM?
It´s not a good connection to China or wherever the server is :-(Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by nguy View PostWhat's new features or benefits are there over the 20140424 version?
Hi Pincer!
I just downloaded Tech1:s custom rom and i asked him about Motion Elf Service that starts preinstalled on these Rom:s, what is that?
Could it be deleted or is it something necessery to keep, and for what?
Pejochto via TapatalkCR11S AP6210 Chipset
CS968 MTK Chipset MT5981 - MT6622
HTC-T018-V04
I have a APP that´s called Appmaster, and if you have a rooted system you can use that app to delete system app:s, if you go into system in that app you will find a lot of system apps that can be deleted that even don´t show up as apps in Android:settings:apps.
I have deleteted a lot of chinese apps there and a lot of system apps that are more in use if you have KitKat installed on a telephone, for instance there is a app that´s called SIM manager, Messages, Exchange Services (If you don´t want that on your box and a lot more...
Cheers!
Originally posted by pincer View Postyou can't delete it, but you can disable it, as far as i know, motion elf is like rk game controller apps. you can choose what input devices you want to use for playing game (wired and wireless) chinese and input devices dependent I think. too bad, the menus is in Chinese. i haven't try it all though.CR11S AP6210 Chipset
HTC-T018-V04
Originally posted by pejochto View PostI have a APP that´s called Appmaster, and if you have a rooted system you can use that app to delete system app:s, if you go into system in that app you will find a lot of system apps that can be deleted that even don´t show up as apps in Android:settings:apps.
Cheers!
Originally posted by nguy View PostUnfortunately AppMaster or uninstall master as it is now called won't delete the chinese apps in this build. Tried removing motion elf - said uninstall unsuccessful!Originally posted by Tech1 View PostIs your CS968 rooted ...?
Originally posted by pincer View PostIt has to be fully rooted.., try installing SuperSU by Chainfire, after install this app, open the app, it will try to install binary files, if success, then your box is fully rooted. if not, you have to re-root your box.
Originally posted by nguy View PostThanks, I thought that Kingroot had rooted the device but clearly it hadn't even though I had tried it twice. Working now - apps removed.
Do it this way, don't pre- the pre-install the SuperUer app, the Kinggo ROOT app will auto install the SuperUser app for you ...
Run the Kinggo app and click on "RooT Again" if successful, your Android TV box will auto reboot ... Open the SuperUser app and follow prop and the correct binary will auto be installed ...
Originally posted by Tech1 View PostOk! If you don't mind me telling you, the way you are trying to root your Android TV box may cause you box not to be rooted ...
There are currently 1884 users online. 0 members and 1884 guests.
