Latest ROM. 1080p kernel. Turn on with Terminal command
CS968 MTK KITKAT ROM 4.4 - Finally
Hello, anyone tried out Google Play Movies on any of the ROMs? When i try to play some movie through it, i get license error. Other devices play it fine..
Anybody ?
i have MTK hw HTC-T018-V4 Dated:20131216 .here is the image: http://imgur.com/4EYpX8B
Please suggest a ROM on which Google Play Movies can play movies fine if its working for someone. Thanks so much...
And BTW, anybody tested out this ROM: https://www.entertainmentbox.com/dro...ware-download/
It seems to be same h/w as it talks of two variants MTK and the other AP6210.
And i contacted the support and they said its android 4.4.4 As far as i know uptill now ROMs available were upto 4.4.2 only am i right?
If anyone has answers to above pls suggest.. Thanks.
Edit:
I tried the above ROM, It works on MTK h/w, but android version is still 4.4.2.
But i am also facing the audio passthrough issue on this ROM. My AV reciever does not get DTS or DD audio when i select any of the other options in the sound manager on this ROM.
Any fix? pincer
Thanks.Last edited by ashjas; 21 January 2016, 07:28.
There are currently 2830 users online. 0 members and 2830 guests.
