CS968 MTK KITKAT ROM 4.4 - Finally
Originally posted by challenger4 View PostTronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by challenger4 View PostI have tried many times installing the drivers via RK_DriverAssistant. Where should I dounlowd drivers from to install them manyally?
Busy with new ROM project for MT7601,MT5931,RTL8188(Q7) & ESP8089.
Those interested can register here, then I'll give instructions later after I give you access.
Here is more information.
Will also create ROM for HPH RK3288 device in a week or two(trying to recoup some costs as it wasn't cheap)
The MT7601 and RTL8188 with bluetooth are fully working.
Only issue experienced was AV sound not working on RTL8188(Q7) for a user. Don't know if it's a big issue, but did create new kernels with HDMI audio fixes and extra sound codecs, maybe it works now. On MT7601 AV sound works.
True 1080p kernels with wifi & bluetooth.
MT5931 & ESP8089 support also added.
Since I updated firmware to 4.4.2 from 4.2.x i can't get my gamepads working. they get recognized but just partially.
I always have the same problem with my RK3288. Now I'm sure it's a KitKat problem.
I would like to get the latest 4.2 release for CS968. Could someone post it here, please?
Best regards, friends!
Originally posted by pincer View PostHere's the new firmware 20140812 and it's fully root.
Note:
- Better compatibility with some apps..,
- Still 720p
- Better Ram management
- XBMC don't have any adds-on pre-installed
Tips: after installing this, make sure you factory reset, and reboot, wait for 5 minutes for it to make adjustments (this will solved wifi issue that don't connect at setup wizard).
Originally posted by ghanashyaml View PostDriver may not be installed correctly. Try installing it again.
ghanashyaml ,
Which ROM are you using with your Android box? Mine is having random rebooting and could not handle 1080p playback on 4.2.2 ROM.
Originally posted by Wildwind View PostHi
ghanashyaml ,
Which ROM are you using with your Android box? Mine is having random rebooting and could not handle 1080p playback on 4.2.2 ROM.Tronsmart Orion R68 Meta
Re: CS968 MTK KITKAT ROM 4.4 - Finally
Originally posted by ghanashyaml View PostHi, I am probably using the latest stock rom with d33 kernel with kitkat. I will confirm the exact version later today. Working perfect with very little blank outs.
Sent from my Nexus 5 using Tapatalk
I have the same CS968 model as yours "HTC_T018 v4 20131216 with MTK" but still running stock rooted 4.2.2 "8188_GT-19300_htc_t018_public_Mtk_20140127_update.img" ROM. It could not handle 1080p (stuttering badly). I found that 4.4 kitkat ROMs did not work reliably and would freeze at the starting logo after a few use and required re-flashing which was a pain so I reverted back to 4.2.2 and most of the issues went away apart from the random reboots.
I also have a CYX-CS918 V2_1 box also running 4.2.2 ROM and have not tried kitkat ROMs due to various ROM issues with the CS968 box. Could someone suggests a reliable basic kitkat ROM for this model
CS968MTK_singleant_root_CSQ_4.4.2_20140904 (can be found in Pincer threads for CS968)
D33 Kernel - kernel_KK_v4.2.5_TVBOX_MT5931_HD from kernel_KK_v4.2.5_MT5931.zip
Kitkat stock ROM has been stable for me. And also the D33 KK 1080p kernel is stable enough with everything working. It does get a bit warm. I do not play games, so it does not get hot.
@stupidy
My D33 kernel above can be found in D33 kernels here. Exact kernel to be chosen will depend on your chipset model/version and SD/HD will depend on your requirements.Tronsmart Orion R68 Meta
There are currently 2068 users online. 0 members and 2068 guests.
