CS968 MTK KITKAT ROM 4.4 - Finally
I can now confirm that the new ROM 20140424 does make your box with 2Gb internal memory and 4Gb SD (Internal, Nand). I didnt know that different ROM could do this with the memory configuration?
But you learn something everyday thanks to the compentence of this forum.
I can also confirm that this ROM is working like a dance on CS968 version 4 board.
Thank you Pincer for all your help and for the work you do to inform us about the things we struggle with.
Super :-)
Originally posted by pincer View Postnope, but beyond xbmc is. but, if you have problem with it, try to reinstalle it.CR11S AP6210 Chipset
CS968 MTK Chipset MT5981 - MT6622
HTC-T018-V04
Originally posted by pincer View PostThe easiest way to know this if not, is by identify what date of firmware you currently use (from factory) (eg. 20140411 (ap6210) or 20140419 (mtk), or 20140313 (mtk) or 20140225 (mtk).
or you can try this ROM first, if the bluetooth and wifi is working, then you have mtk chips on the board, if not, then you have ap6210 chips.
Cheers,
Originally posted by nguy View PostThanks pincer. I opened the device but couldn't find any info. If I apply this rom and the board is not MTK will this damage the box and also what would I need to flash this rom? Is is RKbatch Tool. Thanks in advance
2. check this thread by brick0044, for how to look what chips of wifi and bluetooth on your board, it's place near the usb hub.
3. you can check your factory default firmware in "Setting --> About device"
4. not damage, but you will lost wireless connectivity such as wifi and bluetooth, LAN is still work though if you planning to use wired networking.
5. Yes, you need the RK Batch Tool, dont forget to install your driver with RK Driver assistant.
6. DWYOR
Cheers,
Originally posted by pincer View Post1. make sure your device is CS968/ CR11s or similar, that has Quad-Core Rockchip RK3188 CPU, GPU MALI-400, 2GB RAM/ 8GB ROM and 2MP camera.
6. DWYOR
Cheers,
Maybe a silly question
I've finally got my box working again and planning to flash this rom today. Pincer confirmed that RK Batch Tool is the programme to use to flash the rom which I have. I've taken a look at the program and would appreciate what steps I should take - don't want to get it wrong!
Originally posted by nguy View PostI've finally got my box working again and planning to flash this rom today. Pincer confirmed that RK Batch Tool is the programme to use to flash the rom which I have. I've taken a look at the program and would appreciate what steps I should take - don't want to get it wrong!
Originally posted by nguy View PostI've tried flashing this rom with the RKbatch tool. However, when I tried to flash it I got the following message "layer 58> This operation didn't do because if not supporting! Fail. Can anyone advise what this means please? I have V4 MTK box and rooted.
Tips, make sure the usb cable is firmly attached both on the box and the pc. try to unplug any unnecessary usb devices on your pc.Last edited by pincer; 12 May 2014, 14:10.
Originally posted by pincer View PostI'm sure you have install the driver (those your box recognized by your pc), press and hold reset button upon connecting to pc through otg usb port (near the transflash card on the box), you don't connect the power supply of the box, and the RKbatch Tool has highlighted green on some number like 5-8 or 1-2 and then you hit restore, right?
Tips, make sure the usb cable is firmly attached both on the box and the pc. try to unplug any necessary usb devices on your pc.
The device was connected with the drivers, I did have the power plug connected though. The RKbatch tool was highlighted PINK under 5-8. I will give your instructions a try. Cheers
Cheers!
There are currently 1889 users online. 2 members and 1887 guests.
