Arnova 10G2 Finless Bob's "GingerComb" Custom ROM Version 2.1 CWM
Originally posted by Finless View PostThanks soooooo much!! You are awesome!
Need a graphic artist for games, want a sketch, painting, pm me and we can work something out!
FREAKTAB is FREAKIN' AMAZING!
Kyle
Chrome on Android requires ICS or better. I am not aware of anything other than Gingerbread running on the 10G2.
Finless' GingerComb is Gingerbread with a Honeycomb style launcher embedded.
H
Sent into the innertubes from my Rezound via TapatalkAsus Transformer TF300T - ROOTED, with TWRP recovery and stock Jellybean
HTC Rezound - ROOTED with S-OFF, running stock ICS
Android obsessed since April 29, 2010
First a BIG thank you to all the devs, and most certainly BOB!!! Great rom!!!!
Here is one thing I noticed, when I insert a USB thumb drive it sees it just fine and I can move files and install from it, however the notification for safe removal (Unmount) disappears and all I can do is just pull it out. it then throws a fit about making sure I unmount before removal. Is there an unmount option I am missing somewhere?
Thanks again for all your hard work!!!!!!
Geeve
Known issue with Honeycomb style launcher.
So petrus made a unmount widget
It will unmount it for you BUT you will still get an error message when you pull the stick out.
Geeve
Dowload File Failed
Bob im flashing the latest 2.1 on my stepsons 10G2 and ive run into some problems first the IDB kept failing so after a few tries i got the IDB to rease but when i tried to flash the writing data to flash makes it up to about 175100 out of 248924 to be written and it tells me download failed. Tried starting over but all ive got is power light on but black screen. Can you help me out here any suggestions? thanks
Originally posted by anthonycar9 View PostBob im flashing the latest 2.1 on my stepsons 10G2 and ive run into some problems first the IDB kept failing so after a few tries i got the IDB to rease but when i tried to flash the writing data to flash makes it up to about 175100 out of 248924 to be written and it tells me download failed. Tried starting over but all ive got is power light on but black screen. Can you help me out here any suggestions? thanks
I was able to get the 1.5 rom to succesfully "flash' but the screen is still just totally Black then i tried to reflash the 2.1 Rom and it just failed midway? All seems fine in device manage, rockchip tool recognizes the tab fine, IM stumped and lost sending up smoke signals can i get a rescue?
Everytime this has come up, it is a problem with the PC and the USB port. Try another USB port and make sure you are not going through a USB hub.
Originally posted by Finless View PostEverytime this has come up, it is a problem with the PC and the USB port. Try another USB port and make sure you are not going through a USB hub.
None of that makes sense. It's a a ZIP file. If your download was bad then you would not be able to unzip the ROM kit and you would get a BAD ZIP file error when trying.
You can get the stock ROM from Arnova
Diese Website steht zum Verkauf! arnovatech.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf arnovatech.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Originally posted by Finless View PostNone of that makes sense. It's a a ZIP file. If your download was bad then you would not be able to unzip the ROM kit and you would get a BAD ZIP file error when trying.
www.arnovatech.com
There are currently 1524 users online. 2 members and 1522 guests.
