Arnova 10G2 Finless Bob's "GingerComb" Custom ROM Version 2.1 CWM
Apslib will work if you change back your build.prop. I changed build.prop so it was the most compatible with the Google Play. In doing so Appslib wont run. So edit build.prop back to stock and you can run appslib. BUt you wont get the full GPlay then.
You can swap Build.prop files all day long. You just have to reboot when you replace it. I keep several on my Tablet for just that reason. There is even a build.prop tool on Google Play for doing that.
Originally posted by Gargoyle View PostJust searched the thread, but couldn't find any help.
(I also searched on Google Play, but nothing is coming up there either.)
Is there any way to mount a portable drive that's formatted in NTFS?
I just bought a 1TB portable drive and would like to be able to connect it.
Sent from my SK17i using Tapatalk 2Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Gargoyle View PostI did a search for 'mount ntfs' but nothing came up.
Am I missing something there?
</form>
Originally posted by Damo View Post
Originally posted by petrus View PostMaybe you can try this one : https://play.google.com/store/apps/d...aragon.mounter
Is there something I'm missing? Do I need to change the build.prop or whatever it was, that I read about on some threads, and if so - how do I do that?
Sent from my GT-I9000 using Tapatalk 2
on the gingercomb 2.1a rom the oreinatation sensor is not working nor is the magnetic sensor. to check it out for yourself download android sensor box from the play store and it will tell you. also the video camera on the arnova 10 G2 is also not working. the camera works fine but not the video recorder. if anybody reading this could check this stuff out and post if they got theirs to work, i would really appreciate it. and if finless or damo could provide some information about these issues if they can be fixed or not, that would also help.
i hope its just mine and not everybodies that has this,
kyleThanks soooooo much!! You are awesome!
Need a graphic artist for games, want a sketch, painting, pm me and we can work something out!
FREAKTAB is FREAKIN' AMAZING!
Kyle
Not sure why your having sensor problems. No one else is or has reported it and trust we have had quite a few gamers hammer on this ROM. It works fine on my 10G2 as well.
Have you installed something or modified something that changed it? Build.prop changes can effect how the sensors work! Bottom line, after all the testing by many people, the ROM has no sensor issues out of the box.
Oh and FWI, the Arnova does not have a physical magnetic sensor! Some app report it does (because it has to) but in fact it doesnt have the hardware.
As for the camera. I have stated that the stock camera APP will not record video. But if you use other camera apps they usually work. Skype for instance works. There are other camera apps that will also take video. The problem is with the stock camera app from the Cube and the Arnova hardware.
There are currently 1526 users online. 2 members and 1524 guests.
