nvm i fixed that problem lol but now it isnt saying rock usb found...ive tried turning my tablet back on and trying again multiple times with no luck, but it has the boxes checked...should i just continue moving on with the instructions??
Arnova 10G2 Finless Bob's "GingerComb" Custom ROM Version 2.1 CWM
nvm i fixed that problem lol but now it isnt saying rock usb found...ive tried turning my tablet back on and trying again multiple times with no luck, but it has the boxes checked...should i just continue moving on with the instructions??Thanks soooooo much!! You are awesome!
Need a graphic artist for games, want a sketch, painting, pm me and we can work something out!
FREAKTAB is FREAKIN' AMAZING!
Kyle
Just put your tablet back into flash mode and plug it back into your PC, and carry on with instructionsPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Damo View PostJust put your tablet back into flash mode and plug it back into your PC, and carry on with instructions
my control panel says it has the rock usb installed
the RK29Update says no rock usb found
all the boxes that are supposed to be checked are
it wont let me erase idbs cause it says none is found
im so confused...i followed the instructions exactly and i keep getting this everytimeThanks soooooo much!! You are awesome!
Kyle
Kyle
You are not in flash mode if it shows as usb.
Turn your tablet off
Do not plug it into your pc yet!
Hold the volume up
Press the reset button for two seconds than release while still holding the volume buttom, a few seconds later the tablet will go into recovery mode, the screen goes black.
Connect your tablet to your Pc with the supplied cable.
Now you are in flash modePlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Hold on...hold on.... I have been stating this for a while now about the myths to get into flash mode. YOU DO NOT HOLD ANYTHING for 5, 10, or 15 seconds! Thats total BS! All of this is done in less than 1-2 seconds MAX!
In the end.... It's pretty damn simple!
Have the tablet booted up to the desktop.
YOU MUST HAVE POWER CONNECTED! If power is not connected then the tablet boots a different way!
Now plug in the USB cable. Yes Windows will bong about a device... FORGET THAT... your in USB removable drive mode... We do not care about that for flashing! DO NOT try to install drivers at this point... You will be banging your head trying!
Now while holding VOLUME UP..... Use a pin to hit the reset hole! You will know you hit the reset hole as the tablet will go BLANK screen. YOU DO NOT HOLD THE RESET PIN HOLE ONCE IT RESETS and the screen goes blank!!!!!! Release the reset pin hole right away!!!
KEEP holding volume up for no more than about 2-3 seconds! You should here Windows BONG about a device being connected!
IF YOU HOLD VOLUME UP or RESET PIN HOLE too long, it will put the device into a different mode! This is the mistake many people make. They hold volume up too long (most common mistake) or hold the reset pin hole too long!
Again... REPEAT....
Power plugged in
USB cable plugged in
Tablet is at the desktop
Press and hold volume up
HIT the reset pin hole for NO MORE than 1 second while holding volume up!
Release volume up in about 2-3 seconds NO MORE... By then Windows should have BONGED....
If you hold volume up too long, the tablet will go into a different mode and windows will say something about "Your USB device has failed" etc etc..... If you get that... You held volume up too long or reset AND Volume up too long!
If you don't get the USB device failed message... GOOD... Your in flash mode! Now install the driver.
Hold the volume up
android system recovery utility v1.3.37
*then it gives you options to click on but i dont have buttons so they dont work
reboot system now
factory reset
system recover
Update from SDCARD
Update from uDisk
recovery system v1.3.37
E: Can't open /cache/recovery/command
HELPPPPPP!!!!!!Thanks soooooo much!! You are awesome!
Kyle
Hold the volume up
*then it gives you options to click on but i dont have buttons so they dont work the volume buttons seem to work for choosing though
reboot system now
factory reset
system recover
Update from SDCARD
Update from uDisk
Kyle
Originally posted by Finless View PostHold on...hold on.... I have been stating this for a while now about the myths to get into flash mode. YOU DO NOT HOLD ANYTHING for 5, 10, or 15 seconds! Thats total BS! All of this is done in less than 1-2 seconds MAX!
IF YOU HOLD VOLUME UP or RESET PIN HOLE too long, it will put the device into a different mode! This is the mistake many people make. They hold volume up too long or hold the reset pin hole too long!
Again... REPEAT....
Power plugged in
If you don;t get the USB device failed message... GOOD... Your in flash mode! Now install the driver.
Thanks sooo much that is what i must have been doing...every website i went to someone said 15 seconds so thats what ive been doing and i did keep getting the message but i thought u were supposed to get that message. THANKS!! do you have any idea on my current situation lol i feel like im stuck in a gudder ): should i just select the reboot now and hit the power button??Thanks soooooo much!! You are awesome!
Kyle
Originally posted by bdoggamer535 View PostThanks sooo much that is what i must have been doing...every website i went to someone said 15 seconds so thats what ive been doing and i did keep getting the message but i thought u were supposed to get that message. THANKS!! do you have any idea on my current situation lol i feel like im stuck in a gudder ): should i just select the reboot now and hit the power button??
Please help
okay im freaking out lol i think i will just click the reboot now with the power button and see what happens ); i dont knowThanks soooooo much!! You are awesome!
Kyle
Originally posted by bdoggamer535 View PostI REALLY NEED HELP HERE GUYS!! i understand now what i have been doing wrong but i dont know what to do now ):
Please help
Kyle
I knew you would get it
I think you will LOVE the new ROM dude.... faster then HELL and looks good
PLEASE READ THE README for all instructions!!!!!! The key points are
Click Erase IDB.... and click the loader check box next to the loader line!
OMG i feel so retarded i got it and it looks so amazing!!!! what i had to do is uninstall driver and then turn it on and off and then reinstall it... works amazingly thanks you guys sooo much (: n now i know how to do it for later reference Thanks (: im soo happy and your rite i do love it (:Last edited by bdoggamer535; 12 July 2012, 02:34.Thanks soooooo much!! You are awesome!
Kyle
is that the message you were currently talking about?Thanks soooooo much!! You are awesome!
Kyle
do you think it would be okay for me to put in my sd card and reinstall the backups that i have put on it through the gemini app? would that work or not? (:Thanks soooooo much!! You are awesome!
Kyle
There are currently 1496 users online. 2 members and 1494 guests.
