No output from HDMI
Damm! I already closed my box!
I'll re-open it and take a picture (although there is not much to see)
I'm pretty sure that the case also doesn't give the connector much health...
I noticed that when inserting the pcb in the case, the HDMI connector suffers a bit (the plastic case makes some force and it seems to twist a bit). That may also contribute to break the solder.
I'll post a pic of the final result in a few minutes.
Re: No output from HDMI
Sent from my HTC One_M8 using Tapatalk
One person already reported that he broke his HDMI port taking it out of the case!
So be careful out there......
Originally posted by pyn View Post...I noticed that when inserting the pcb in the case, the HDMI connector suffers a bit (the plastic case makes some force and it seems to twist a bit). That may also contribute to break the solder...RK3288 Devices
- Overview BOX (LINK !)
Well i'm happy to report that I got it working. It's utter crap that I had to heat up the solder points on the HDMI port for it to happen. It now displays video through the HDMI port. Pyn was right, i pushed the HDMI port down on the PCB and it lit up the port without having to jack with the cable. So I fired up my soldering iron, melted a little solder on the tip to create a hotspot, flipped the board over and found something small enough that I could press the HDMI port down on each corner as I heated up the connection point. After doing all 4 i'm happy to report that the connection and display is solid even with moving the HDMI cable around...AS IT SHOULD BE FROM THE FKING FACTORY.
I don't like having to crack open my brand new devices that I spent over $100USD on. Shame on Geekbuying.
Originally posted by djmatix View PostWell i'm happy to report that I got it working. It's utter crap that I had to heat up the solder points on the HDMI port for it to happen. It now displays video through the HDMI port. Pyn was right, i pushed the HDMI port down on the PCB and it lit up the port without having to jack with the cable. So I fired up my soldering iron, melted a little solder on the tip to create a hotspot, flipped the board over and found something small enough that I could press the HDMI port down on each corner as I heated up the connection point. After doing all 4 i'm happy to report that the connection and display is solid even with moving the HDMI cable around...AS IT SHOULD BE FROM THE FKING FACTORY.
It seems that the ground planes are causing solder reflow probs. (Not enough heat).
Cheers!
Thanks a lot for this tip. So I pressed the port very very hard (until my thumb goes white) and I get a picture back. So it makes me happy to hear that only the 4 mounting point have to fixed. This is large enough for my soldering experience. If the small data pins where also loose, I had to give up. So I will test it tomorrow and give back result.
There are currently 3833 users online. 0 members and 3833 guests.
