No output from HDMI
I bet you I know what happened. I'm sure every single one of these devices work fine on the bench, which is where all of these quality control stickers come from. I wouldn't go and blame the soldering guy (maybe), i'd blame the idiot who designed the round case and the tight tolerances for the PCB. I still can't get the damn thing back into the case, and i'm using some not so nice force to get it in there. So here it sits, out of its case, but at least its working. The hell with this.
Originally posted by djmatix View PostI bet you I know what happened. I'm sure every single one of these devices work fine on the bench, which is where all of these quality control stickers come from. I wouldn't go and blame the soldering guy (maybe), i'd blame the idiot who designed the round case and the tight tolerances for the PCB. I still can't get the damn thing back into the case, and i'm using some not so nice force to get it in there. So here it sits, out of its case, but at least its working. The hell with this.
The two boxes i've opened had the IR sensor bent back flat (had shitty remtote function!). Poor assember had he's/hers days (obviously) to assemble the bloody thing and in the process the pinkie pressed down on the sensor. Did it myself the first few tries. Give them time, soon they will assemble them in < 30mins without damaging the connectors.
Well, in my case I had to (re)solder the tiny pins of the connector...
I guess that heating up the 4 big ground pads while pressing the connector against the PCB might help the other little pins to make contact (even if they aren't properly soldered) but that doesn't seem a solid solution for everyone.
But maybe a solution to correct the fitting in the hole if it looks like this http://www.freaktab.com/showthread.p...ol-it-down-%29RK3288 Devices
- Overview BOX (LINK !)
Ok, i am also f**ked by this factory... read so many complaint about the no hdmi out put problem.
guys, we really do the test, and each device have hdmi output when the factory give the device to us.
I have talked serious with factory, they think it maybe caused by the cold welding technology in first bulk so they improve that in next bulk. however, more and more first bulk customer report the problem make geekbuying like shit on this device.
ok,here is our solution:
1 if you don't have hdmi output when you receive it, just contact our customer service, we won't give you pain on return to us, return shipping cost is handle by us;
2 i will confirm the factory again,and if they can't promise the problem is removed in second bulk, then, no more sales till they fix it.
Geekbuying Don't WANT TO SELL SHIT, I know new products maybe have software problem, but hardware bugs is not allowed in my mind.
forgive me, guys.
Sorry.
EricLooking for developers
Originally posted by geekbuying View PostOk, i am also f**ked by this factory... read so many complaint about the no hdmi out put problem.
forgive me, guys.
Sorry.
Eric
forgive me, guys.
Sorry.
Erici am pretty good with a soldering iron, but that's not the point
AddySent from my Commodore 64 using Geos
My devices:
Tronsmart Vega S89-H: running stock 104k4 rom, rooted & racky's cpu fix.
Samsung Galaxy Tab 10.1: running KK's dual boot kernel, Phil's touch recovery & de-bloated, over-clocked and rooted stock rom.
Samsung Galaxy S3: stock until warrany is over lol running JB 4.3 ...
HTC Incredible S: Venom rom, 'kangaroo' kernel, overclocked to 2Ghz & still kicking the Sammy's butt!
Originally posted by Addyhash View Postsh*t, i'm not sure if i still want one now... is mine gonna be from from first batch, or am i now gonna have to wait even longer for another batch ( i pm'd you my order number on Monday ) , still showing 'processing' at geekbuying page...i am pretty good with a soldering iron, but that's not the point
Addy
Addy
Remember there are lots of these device in the field and only few give problems - especialy those that had the HDMI plugged many times (Like my dad). People typically do not have enough HDMI ports on their TV/aV and have to swap out the devices all the time - that buggers the HDMI socket quickly it seems. (Or they ticker allot with it).
Originally posted by geekbuying View Postno,no, not every device in first bulk have problem, we sold 2000pcs, but only less than 20 person to report the problem. the rate is lower than 1% also no more first bulk because that has been shipped all... and i have called factory to confirm, he promise the problem sovled, now i am testing, plug, unplug, plug, unplug to test.......
EricOriginally posted by Lokie View PostI bought 4 first batch devices. 1 has HDMI gone bad. My dad is posting he's defected device to me - will tack it with the solder iron and see if I get lucky.
Remember there are lots of these device in the field and only few give problems - especialy those that had the HDMI plugged many times (Like my dad). People typically do not have enough HDMI ports on their TV/aV and have to swap out the devices all the time - that buggers the HDMI socket quickly it seems. (Or they ticker allot with it).... best i plug the hdmi in and never touch it again lol ;P
My devices:
Eric
Hello Eric , my s89-h was shipped, date: 5/22/2014 9:27:22 AM, is from first bulk, or not. thanks i wait your answer.
There are currently 2570 users online. 0 members and 2570 guests.
