Pipo M9 Pro RileyROM 3.0
    Originally posted by Thoma View Post
    Thank you I'll try that!
    Thanks it works great!!
      The new ROM is still in the testing phase, but I have a ROM testing thread in the same section. I plan on releasing 1.0.3 tonight with a couple of fixes.
      This new ROM is finally better than v3.0.1.
      Stevejc is still working on a new kernel.
      Randy
        slowly but I don't give up
          @stevejc can you add memory swap support in the new kernel pls
          PROUD owner of PiPO M9 Pro
          PiPO P9 best tablet ever owned!!!
          PiPO Tablet Freak and Flashaholic!
            Is it possible to receive SMS with this version? I have a M9 Pro 3G and I'd like to at least receive text.
            Kind Regards
              Whaaaaaat a ROM better than 3.0.1. I love this rom. What is better?
                Hi, i was wondering if the ROM is available?
                Thanks for your hard work.
                  I believe the ROM is completed, we are just tweaking the kernel for it.
                  If you want to do some testing and reporting, feel free to check out this thread:
                  Randy
                    What would be the best streaming dongle for my m9 using this rom?
                      Hi. Please confirm...is It just me o rmay be others? FirmwarePipo M9ProRileyROM3.0.1(core407, and406as well). On any other firmware from the site 4PDA also. The issue is when playing streamingvideo and audio are not synchronized from behind videos about 1-1,5seconds. A Youtube video being played synchronously with the audio. For example, check to watch TV here from these applicationshttps://play.google.com/store/apps/details?id=com.spb.tv.am&hl=ru or here it is http://www.ontvtime.ru/general/tvc.html. Add the following - I have a CUBE U30gt tablet the first dual-core version.This problemis not there. What is the reason?
                        For this ROM I applied all of the streaming improvements I could. I'm not sure exactly what the problem might be.
                        Randy
                          I stream from Primewire and all is great.
                            When I try to install any rom, it all goes well at first but at rebooting there is a hard click and then the tablet turns off.
                            After that the tablet won't turn on again.
                            I tried to install the standard rom of Pipo and this Riley Rom.
                            Can anyone help me?
                              Which is the latest/tested and working Firmware? is it Riley Rom 3.0.1 or the freaktab team 1.0.3? Or is there a newer version that I am simply not seeing? aHave tried each of these and though I had the odd initial crash both seemed very good except my Sygic navigation software no longer works (probably a sygic issue or some old data on my system).
                                hi, after flashing my pipo m9 pro the touchscreen doesn’t respond. i tried with 3 ROMs diferents and is the same. I see the home screen, the launcher but any place i touch doesn’t works. any suggestions?
                                note: before flashing i opened it to fix the ESC button. (i dont know if that could cause something)
                                please i need a solution quickly.
                                thanks
                                mariano
