Pipo M9 Pro RileyROM 3.0
    CAUTION: This IS a KitKat ROM...so do your homework on flashing KitKat ROM's before you get started...if you are upgrading from a Jellybean ROM. If you think KitKat isn't for you, visit the main Pipo Forum for instructions.
    This ROM may be the last we see from Pipo for the M9 Pro, so I decided to call it v3.0. Believe me, I have been trying to modify that last versions on my own without much success...so there were other versions I never released.
    This ROM is based on official Pipo firmware (still from beta testers, not from the Pipo site). Thanks to all of you users who saw this before I did.
    One thing I have noticed is that QuickOffice now works and saves files to your SD card. We will have to wait and see what other fixes are in store.
    This ROM has all of the usual RileyROM features:
    Rooted
    Debloated
    Init.d support with Busybox commands
    English Default
    Google Play Store fixes
    Updated Google Apps
    2, 4, 6, 8 or 12gb user app space by selecting the desired parameter file
    Auto Install feature added for installing apk files on first boot from external SD
    TWRP recovery installed on first boot by Abdul_Pt
    Reboot app by Petrus
    New boot animation by me
    Latest revision of the First Time User's Guide
    Flash Tool by Finless
    All made with a variation of 900SuperSport's Freaktab Kitchen
    Edit: This is now v3.0.1
    The update fixes the Exchange email bug, and includes kernel 407 in the kit as an optional kernel. The default is still kernel 406.
    Download
    EDIT: You now have kernel options
    The default kernel in this ROM is kernel 406. We've obtained a copy of kernel 407. If you are interested in experimenting with switching out kernels to compare performance and functionality differences feel free. In the flash tool, just uncheck everything except the kernel line and direct the flash tool to the desired kernel you want to flash. Don't erase IDB, or you will have to flash the whole ROM over again.
    Kernel 406 (already included in the ROM kit)
    Download
    Kernel 407
    Download
    Please donate to support RileyROM's on Freaktab.
    Randy
    Don't install updates on QuickOffice. The factory version works...but the update doesn't.
    Randy
      Just flashed now an testing/setting this new KK rom...will report later
      the only thing i hate is the boot animation screen..i always change it to stock pipo one
      PROUD owner of PiPO M9 Pro
      PiPO P9 best tablet ever owned!!!
      PiPO Tablet Freak and Flashaholic!
        is RR 3.0 based on this FW "PiPO M9pro_update_andriod4.4_20140504.img"?
        http://pan.baidu.com/s/1sjlUgDv
        Proud M7Pro owner and Freaktab fan
          Re: Pipo M9 Pro RileyROM 3.0
          Sure... New rom new thread
          Sent from my M9pro using Tapatalk
            when i click 'reboot to flash mode' it changes to NO FOUND RK ANDROID rock USB.
            and i have to reboot again, but doesn't stay in flash mode
            Any ideas ?
            Ok now, reinstalled the drivers
              now i have some questions .
              i read that if i update quick office , it will nor work . is this true ?.
              What else is not working normal? who test ?
                v3.0 rom works wonderful, no bugs so far another awesome custom rom from randy!
                  okay i now have a pipo max m9 pro
                  due to i send my Pipo max m9
                  for repair they send me an pipo max m9 pro 32 gb
                  back so i now also have a pro tablet
                  hey i flashed i got some error about cant mount ext sd
                  (i dont have one inserted)
                  and 1 about metadata
                  but thats i think because i is different with kitkat
                    Yes it's true, Quick Office will be fuc.ed after update.
                    Kingsoft Office is working normal, saved/modified a .docx file on internal/external memory without any problems.
                    In home screen applications shortcuts will display text under icons.. in R 2.7.2 is not possible with stock launcher.
                    GPS is working fine here, first fix under 2 min. with 16 meters accuracy.
                    No flickering keyboard as far i can see until now.
                    HW+ decoding mode with custom codec in MX Player is working fine, in RR2.7.2 i was not able to accomplish this.
                    Deep sleep will not be triggered until modem power will be disabled, is not able to keep modem power in off state after every reboot/start.
                    Antutu score is a little bit lower, only 19100, on RR 2.7.2 was 20200 pts.
                    One thinig is not very clear for me, and maybe is very important for us...KERNEL VERSION used for this ROM:
                    As far can see, Kernel Version used here by Randy is:
                    3.0.36+
                    root@alex-System-Product-Name#406
                    Tue Apr 15 12:23:42 CST 2014
                    Looking through Arctablet forum and have noticed that they have used a newer kernel version in latest build:
                    3.0.36+
                    root@alex-System-Product-Name#407
                    Sun May 4 11:18:12 CST 2014
                    Which kernel version is more evolved and bug free ...that's a completion for a great ROM.
                    Thank you Randy ...you did it again.
                    L.E
                    We have provided 3 or 4 links for original ROM to Randy...which one has been used for this ROM?
                      no tablet ui
                      hey i have set
                      ro.rk.systembar.tabletUI
                      to true but it doesnt work if you know what i meand
                      i doenst make button on bottom
                        ok thanks )
                          ok thanks )
                          hey quick office updated version work here fine
                          maybe its due i didnt open the factory version first
                            Yes...that's the one.
                            Randy
                              That's what I said in post #2. Based on my own observations.
                              There aren't any change logs...as usual.
                              Randy
