But in my case, none of the kernels worked for me, my tablet stuck on Riley fireman logo. I reverted back to #406.
Pipo M9 Pro RileyROM 3.0
Originally posted by rrileypm View PostWow, much has happened over night!!!!!!!
Sounds like we have a couple of issues related to app updates. But once the apps are updated, everything works, OK?
How about that root problem, is anyone else having trouble keeping your tablet rooted?
About the OC kernels....keep in mind that this ROM was tuned to the 406 kernel. That's your baseline. Take a methodical approach to trying different kernels and keep a record of your results. (especially dealing with older OC kernels). Remember, this new firmware was intended to fix certain problems, which may return if you flash an older kernel.
no issues nothing
no no root issue
no app update issue
only battery drain
Originally posted by blusydays View PostI've just found the link for overclocked kernels, here it is https://www.facebook.com/notes/pipo-...41518722600922
Enjoy
OK, it sounds to me that the kernel patcher guys need to concentrate on making patched versions of 406...which is the kernel contained in this ROM.Randy
Originally posted by Kenneth View Postlink downOriginally posted by skippie View PostThis content is currently unavailable
To get the kernel, you have to :
1 - Join this Pipo Phillipines Facebook Group : https://www.facebook.com/groups/pipotabletsph/
2 - Go to "Files"
3 - Look for "M9Pro Modified Kernels" and click on it
But as I said before, non of the kernels had worked for me :/
That will come from patched kernels.Randy
Originally posted by robinjoo1 View Postwhat you mean plz say if you can fix battery drain
is this rom from this firmware?
Battery drain has always been a problem with the M9 Pro...you can read back all the way to v1.0...we have tried several remedies...but the solution has always been to tweak the power settings in the kernel.
Giouncino says he will work on some kernels from both 406 and 407 for us.
Randy
Originally posted by rrileypm View PostBattery drain has always been a problem with the M9 Pro...you can read back all the way to v1.0...we have tried several remedies...but the solution has always been to tweak the power settings in the kernel.
http://www.freaktab.com/showthread.p...720#post184720
ok great news great
really
netflix works
spotify works
no wifi black outs
ok im now on kernel #407
1 difference for me faster updates installation
faster wifi
faster netflix video loadingLast edited by robinjoo1; 27 May 2014, 19:00.
Re: Pipo M9 Pro RileyROM 3.0
Sent from my M9pro using TapatalkPROUD owner of PiPO M9 Pro
PiPO P9 best tablet ever owned!!!
PiPO Tablet Freak and Flashaholic!
Originally posted by Kenneth View PostBattery drain is due of the hi-res lcd screen used on the m9pro, the Rk3188 barely consumes power as it is manufactured on 28nm topology. I don't know why PiPO used a 7800mah battery to compensate for the lcd screen drain, an 8000mah battery would be a bit better.
btw im now on kernel #407
is wifi is better than s3 with art mode
There are currently 2215 users online. 0 members and 2215 guests.
